Hahn 20g Install questions
Old Nov 15, 2012 | 07:34 PM
Facepalm_IRL's Avatar
I'm sure some of you guys have swapped to a Hahn 20g on your LNF so, what were some of the issues of the install, ad what is the degree of difficulty for the job?
Old Nov 15, 2012 | 07:46 PM
Fastgti69's Avatar
I heard you had to machine a part of the exhaust manifold to make it fit exactly. That's it AFAIK.
Old Nov 15, 2012 | 07:51 PM
That doesnt sound TOO bad.
Old Nov 16, 2012 | 02:13 PM
AARON-SS-TC's Avatar
damn, i didnt know you had to do anything to make it fit.
Old Nov 16, 2012 | 02:56 PM
I'm not sure, thats why I'm asking.
Old Nov 17, 2012 | 03:39 AM
Macgyver2484's Avatar
I wrote a guide on the ZFR turbo install. If any grinding has to be done on the exhaust manifold, I bet it’s in the same position I had to grind. With the exhaust housing being larger - this is the first place it hits preventing the parts from bolting together all the way.
https://www.cobaltss.net/forums/how-...allion-287559/
Old Dec 7, 2012 | 01:37 PM
lazaro's Avatar
I had a a hahn 20g and you have to grind the flange they send you. Im back on stock turbo,now cause the old motor had low compression on all 4 cylinders and got a new motor and turbo from the dealer
Old Dec 7, 2012 | 03:13 PM
05RallyYellowSS's Avatar
How did you like the 20g when it was on there?
Old Dec 7, 2012 | 04:57 PM
lazaro's Avatar
I cant tell you man the car ran bad it was running 110 on the compression test and it suppose to be at 150 or so i read i was pushing around 350 on pump gas on 22 psi
Old Dec 7, 2012 | 05:19 PM
user 72239's Avatar
S20G isn't bad, its a good turbo for the price. It sounds like the guy above me just had bad luck. I did a compression test on my car and I read 125 across the board...but im at 5500 ft above sea level....sounds like a crap tune.
Old Dec 7, 2012 | 08:32 PM
lazaro's Avatar
Yea i had bad luck, i still have the 20g laying around but im gonna with the zfr. The spool on the 20g sucks lol fullboost by 4500rpms
Old Dec 8, 2012 | 01:10 AM
Nfamous60's Avatar
^^^damn.....
Old Dec 8, 2012 | 01:34 AM
4500 really sucks. you positive it wasnt just the tune making it that way?
Old Dec 8, 2012 | 02:26 AM
lazaro's Avatar
I was trifecta tuned the hp tuned and the lag was the same. Idk if it was the weak motor causing lag, another thing was i also had a week vacume. It sat at 17 with ac off
My car was fucked up and runing like **** were gonna swap the turbo to another lnf down here and see of the results are the same,
Old Dec 8, 2012 | 02:37 AM
Chevycobaltss3's Avatar
Btw (I didn't tune his 20g) just letting everyone know
My full spool to 26lbs was 3200 4th gear and 3600-38003rd gear
Install is easy... Remove exhaust housing and install that by itself. It'll give you more hand room. Then install the cartridge and compressor housing and bolt up the wastegate. Easy..
Old Dec 8, 2012 | 02:38 AM
My 63mm 25g setup full spools by 3900 4th gear and 3rd is 4200
Old Dec 8, 2012 | 05:20 AM
Fastgti69's Avatar
I want this. Trade my EFR for a couple months? LOL
Old Dec 8, 2012 | 06:47 AM
40rty's Avatar
Let me ask this here again is 500+ "WHP" possible on the Hahn 20G on E47? This is for everyone not just James.
Old Dec 8, 2012 | 09:48 AM
user 72239's Avatar
The general consensus is no. Hahn said they made like 450 whp with the 20g with E85 but I don't think anyone could match those results. Most I've seen is 400 whp with E85 with the 20g. full boost Spool should be around 3200 to 3500
Old Dec 8, 2012 | 09:53 AM
No, turbo flows 650-675cfm so only way possibly. To even hit 450 is high boost with a fuel additive for octane.... 500chp is possible more then likely but not 500whp
Old Dec 8, 2012 | 10:07 AM
40rty's Avatar
Thank you, i have been saying this since day one to another Kappa member that openly states to everyone that he is putting down 500+whp on E47. It drives me nuts because he misinforms people on the forum which have bought the kit from Hahn because of his claims but don't come close to his numbers.
Old Dec 8, 2012 | 10:14 AM
A turbo can only push so much power out. 650-675 cfm is roughly 500most (crank HP) and that's literally up there in boost and a whole lot of timing... 52mm in and 49.2turbine.. Doesn't have enough to push out 500whp
Old Dec 8, 2012 | 10:23 AM
lazaro's Avatar
Yea, guys im just saying my personla experience, my original motor got hydrolocked then the insurance got me a random engine with that engine the car never ran the same. for some reason everytime we raised the boost past 25 the car would break up nasty for unknown reasons. Ill have futher updates im selling it to a friend and lets see if he has better luck
Old Dec 8, 2012 | 10:38 AM
40rty's Avatar
Ummm is your friend at least going to rebuild the thing or take it apart for an inspection? Make sure everything is good to go?
Old Dec 8, 2012 | 10:49 AM
lazaro's Avatar
that turbo only has about 5k miles, he gonna inspect it either way just to make sure but i dont think their anything wrong with the turbo
