Hahn Charge Pipe Dented Hood
Old Jun 7, 2010 | 04:14 PM
D-mac's Avatar
I went to the track this weekend
I just installed my Hahn CP setup on Friday
During the course of drag racing the Hot Pipe came up and caused a dent in my hood
Dent with 4 little dents around it, Paintless Dent place might not be able to fix it
Anyone with the Hahn kit have to modify the length of any of the pipe or somehow tie the pipe down to the engine?
Any pics or suggestions as this is a huge **** off with a Brand New 2010 with under 2000 miles on it
Thanks
Old Jun 7, 2010 | 04:21 PM
northvibe's Avatar
sorry to hear about that did you make sure it was pushed down into the couplers etc?
Old Jun 7, 2010 | 04:23 PM
glhs379's Avatar
Mine did the same. Wheel hop is killer you have to get that fixed and make sure the upper pipe is seated all the way down into the lower driver side pipe I pushed mine down a bit after it dented the hood. Good painless guy will fix you up
Old Jun 7, 2010 | 04:25 PM
ericgt79's Avatar
if it did that than you have the pipes on backwards. they might look correct but if they are pushing up that far more than likely they are not.
HB_SS/TC's Avatar
Need tbolt clamps and tighten them up
Old Jun 7, 2010 | 04:26 PM
Berto09ss's Avatar
well i think i have the same problem but idk if its the charge pipe or my AEM intake
Pix would help..i dont have a dent but i think either one is making my hood not align right
Old Jun 7, 2010 | 04:36 PM
D-mac's Avatar
I am running the Tbolts from Hahn
Hot side upper pipe is pushed tight against the pipe coming from the Intercooler
How could i have the pipes wrong?
Pipe hit the hood right at the bend of the Upper Hot Pipe
The lower hot pipe coming from the intercooler is also chattering at the bottom on that cross piece
Anyone had to cut one of the pipes?
Old Jun 7, 2010 | 04:38 PM
BYT*SS*TURBO's Avatar
Pics?? (of pipe installed and dent)
D-mac's Avatar
I will go out and get some pics just charging camera battery, will post in under 30 mins
Old Jun 7, 2010 | 04:39 PM
Berto09ss's Avatar
plz
Old Jun 7, 2010 | 04:42 PM
Supercharged Guy's Avatar
I'm pretty sure you dont have to cut them, I dont have the hahn upper cp, but
They wouldn't sell a upper cp that after you buy it, you have to turn around and cut it
It's not 100% that all aftermarket parts will fit as if they were stock so you might just have to play around with it to fit perfectly
Oh and I'm sorry about the hood man that does suck a lot
Old Jun 7, 2010 | 04:45 PM
Berto09ss's Avatar
hmmm maybe..but yeah i dont think u have to cut anything though...I know this is off topic but i dont think my aem intake's elbow has to rub my a/c line,right??
I dont mean to jack this thread
Old Jun 7, 2010 | 04:48 PM
HB_SS/TC's Avatar
Install error for both of you
I dont believe so lol but then again I dont have the AEM Intake so I can't really be a big help to you
Old Jun 7, 2010 | 04:49 PM
Gestapo007's Avatar
im training in paintless dent repair, i woul dlike to see the dent as well
Old Jun 7, 2010 | 04:51 PM
Berto09ss's Avatar
well maybe the pipes
but the intake is a simple install so idk how i can mess it up
Old Jun 7, 2010 | 04:52 PM
D-mac's Avatar
I can't see how i could have installed this CP setup wrong
Its pretty straight forward
But you guys can tell me once i post pics
Old Jun 7, 2010 | 04:57 PM
Berto09ss's Avatar
yeah this would help if we had pix D-mac
HB_SS/TC would u mind posting some??
Old Jun 7, 2010 | 06:18 PM
D-mac's Avatar
Here are pics
Shot of hood, dent is hard to catch but its a dent with a few small ones around it
Even if im getting wheel hop this pipe shouldnt hit my hood
Here are pics of the piping
This mark was kinda there when i got the piping so it must have hit someone elses hood also, as i got it from someone else, it hit my HPTuners decal
Old Jun 7, 2010 | 06:26 PM
Do you have the upper and lower pressed together tightly?
Old Jun 7, 2010 | 06:28 PM
D-mac's Avatar
Yup they are butted together
Old Jun 7, 2010 | 06:30 PM
glhs379's Avatar
mine did the EXACT thing
wheel hop is what did it, as in first the car hopped very bad causing the pipe to hit the hood.
my local paintless guy fixed me up for 75 bucks
Old Jun 7, 2010 | 10:25 PM
D-mac's Avatar
What have you done to prevent it again?
Old Jun 7, 2010 | 10:35 PM
HB_SS/TC's Avatar
Are you SURE the top pipe is pressed all the way down to the lower one?
Or get a hood blanket lol
Old Jun 7, 2010 | 10:49 PM
D-mac's Avatar
Yes the pipes are pressed together end to end
Hood blanket? Would a piece of rubber stuck under the hood disperse the impact?
Im going to get a set of OTTP Stage 2 Mounts as im sure wheel hop helped cause this
But there has to be a way to safe guard this
