hahn intake help
hahn intake help
Hey guys need some help. I have a Hahn cai and Im Thinking the MAF sensor is giving me problems. Some symptoms are running lean at idle, backfire, tries to die when starting off in first gear, and sometimes while driving it will seem like the car will accelerate by it self then I'll have loss of power. Also the intake will whistle on start up pretty bad also while driving even though I'm not on the gas.
Could it be the MAF sensor needs cleaning or could it be something wrong with the trifecta tune?
Yes I've been tuned for the mods on the ss, I've went through 3 oxygen sensors on catless downpipe, and every once in a while it will through a p1040 code for o2 sensor then go away and also the scanner says it runs lean at idle
You'll need a K&N drycharger too, otherwise you'll get all sorts of awful things happening when it rains. It'll even do weird things (due to condensation) after you park it for a night, if the filter is wet.
