Hahn MODpipe and 3" cat back :)
Old Feb 28, 2009 | 08:21 AM
Hawaiian Whore's Avatar
after 4.5 hrs of being underneath the slobalt, my 3" turbo back exhaust is complete... i got the modpipe, and am currently running the catless option, followed by the hahn 3" cat back... the car responded amazingly to it, and sounds like pure sex! i've never heard an exhaust note like this, it's quite mellow, and even w/ no cat, it's not raspy at all... i was quite surprised w/ how well everything fit, and even more surprised how amazing it sounds! you can barely hear the turbo thru the exhaust from the cabin (from what i'm told, it's more audible outside the car) i def. picked up a noticeable gain in bottom end, and top end... the mid range stayed the same, but now at 2.5-3k rpms i'm almost at 22 psi... anyone w/ a turbo balt, i recommend this in a heart beat
Old Feb 28, 2009 | 09:10 AM
TurboTechRacing's Avatar
Awesome review/write up
Old Feb 28, 2009 | 09:15 AM
sherm420's Avatar
i have his catback just need the d/p but i might be going with cia for that
Old Feb 28, 2009 | 10:16 AM
orbalt08's Avatar
Sounds great. Pics or vids of the install or the finish?
Old Feb 28, 2009 | 10:25 AM
Terminator2's Avatar
You are tuned correct?
Old Feb 28, 2009 | 10:53 AM
BartSS's Avatar
I should be getting a full turbo back soon
Old Feb 28, 2009 | 12:24 PM
Boosted_Cobalt09's Avatar
great to hear that the product has good responses ill be ordering a bunch of parts from then soon.
Old Feb 28, 2009 | 01:33 PM
COHBALTSS's Avatar
Nice, 4.5 hour install isn't bad for a full exhaust either
Old Feb 28, 2009 | 01:35 PM
1badBlueberrySC's Avatar
Yes he's tuned... with my tune on his car!
Old Feb 28, 2009 | 03:01 PM
yeah, tuned, and what not...
the exhaust really shouldn't have taken that long, i was kinda goofing off while doing it... the only hard part is the top bolt of the begining of the catback, that was a ***** *****! anyways, i'd post vids, but it's pouring ass rain outside
i'll write a review in ab a week after i get a feel for it
i figured the modpipe would have leak probs bc there's no gaskets between the 3 separate parts, but so far it's holding well, no leaks anywhere. the stock dp looks to be ab the same size as the 3" dp, minus a cat (which btw, the stock dp is heavy as ****!) this tone is still unbelievable, it's not raspy or ricer, it's a deep, mellow tone, that growls at WOT...
Old Feb 28, 2009 | 05:01 PM
The stock downpipe is 2.5" the collector/ flange might be about the same size on both though!
Old Feb 28, 2009 | 05:23 PM
Stock DP is 3". Stock catback is 2.5"
Old Feb 28, 2009 | 05:57 PM
my bad I was under the impression it was the same as the SS/SC's!
Old Feb 28, 2009 | 08:15 PM
ian48065's Avatar
i know this is a noob question but do you throw a cel with out the cat?
Old Feb 28, 2009 | 08:50 PM
Hahn's non catted downpipe is desgined not to throw CEL At least most, if not all have stated this.
Old Feb 28, 2009 | 08:54 PM
rockkrawler628's Avatar
I was wondering the same thing? He said he has a tune, so most likely the DTC is turned off... but my question is... can it pass emissions when the DTC is turned off? Cause if it can't then wth are you gonna do when it comes time to do it? You'd have to put the stocker on and get a new tune???
I'm thinking it'll still pass emissions cuz thats just to much damn work.
alright my 1st question was answered....
So it'll still pass emissions just not inspection??
Last edited by rockkrawler628; Feb 28, 2009 at 08:54 PM. Reason: Automerged Doublepost
Old Feb 28, 2009 | 09:53 PM
if your state isn't retarded like NC yes. I know in Missouri they don't hook a computer up to your car or nothing they just do VISUAL inspections!
But usually catless means "NON-DOT" approved or "OFF-ROAD ONLY" so NO
Old Feb 28, 2009 | 11:17 PM
lol figured... the main reason I asked is because my jeep threw a code for the cat.... and in PA they hook **** up to the computer so the computer reads the ECU DTC's to see if all the parameters are met... and if they arent it wont pass... so if the exhaust code is deleted... i figured it pass but i guess not.
I want a SS/TC but wanna run straight exhaust. I don't wanna have to retune just for emmissions but i'll figure something out.. o well
Old Feb 28, 2009 | 11:30 PM
tune won't effect the emissions testing... unless you are just reatardedly RICH!
Old Feb 28, 2009 | 11:43 PM
so when the DTC's are deleted so the check engine light won't appear... it will not effect emissions testing? even tho the car wouldn't pass with the DTC not deleted...
sorry in advance for being a retard
Last edited by rockkrawler628; Feb 28, 2009 at 11:43 PM. Reason: Automerged Doublepost
Old Feb 28, 2009 | 11:44 PM
ColeJJones's Avatar
Bannned
its about 3.5 hours to long
Old Mar 1, 2009 | 02:58 AM
i haven't thrown any codes yet, so the modpipe is doing it's job... also, the great thing ab it is that i can still put a cat on w/o having to change the whole dp
^^^i could have been done a lot sooner, but like i said, i was clowning around
Old Mar 1, 2009 | 01:46 PM
COHBALTSS's Avatar
Really, an hour for a full TBE exhaust? I come from a Mazdaspeed3 where the DP alone is a fuggin 4 hour nightmare
Old Mar 1, 2009 | 02:18 PM
davidcroft's Avatar
If you have a lift and all the tools required, set aside. On your back in a garage is a diff story.With all the set up and clean up and all the bs-ing in between, that sounds about right.
Old Mar 1, 2009 | 03:17 PM
DGAF260's Avatar
no frozen nuts or studs its possable SI says .6
