Hardly any boost in 1st gear
when i first bought the car i was geting about 15psi in first it went into chevy to get some work down to the paint and it came out only giving me at most 4 psi in 1st.. any idea's y?
There is a point where you can have too much boost and too little boost. You want just enough to not get wheel hop or wheel spin.
Factory boost is set to 200% in first gear, so IDK why you wouldn't make boost. I know that you don't have as much time to build pressure if you floor it and shift early. Plus if you are stock you have less RPMs to make boost as well.
ummm i'm boosting 15 psi in first so not sure maybe it depends on where you live, maybe the car is already making its max power in first easier then other gears not sure, but mine is fine
my car makes 15-16 psi in first. but what i think ur doing wrong is when ur rpms are higher in first gear and then u floor it, thats when u dont get alot of boost cause ur almost to redline. for max boost, u have to let off the clutch and baby it in first, when ur rpms is low then u mash the bitch and ull see a difference
if not then maybe somethigns wrong, but thats what i do
Yeah i have noticed that very true, got to give it time to spool
I can roll into the throttle or mash it and I still only get 4PSI in first. Your not the only one :-/ The car seems to be creating plenty of power. Maybe it only needs that much boost because of my elevation or something. I think it is creating the proper HP.
SS/TC:
2200 miles on mine... full tire roasting boost in first gear
try taking the traction control off and see what it does. it may be limiting you
Last edited by 08blackbaltss; Jul 22, 2008 at 10:37 PM. Reason: Automerged Doublepost
