Having some issues with my car
Old Oct 6, 2011 | 07:16 PM
TommyP's Avatar
AWD > FWD
Ok, for a while now I've been having some odd issues with my car, mostly weird cold start ups, and some surging while driving, but it'd go away quickly then the car would be fine for a while. Tonight as I was driving, car started to struggle, wouldn't boost past 5 psi, and threw an unmarked p0101, which as I was aware was a MAF code. I had to check my interceptor to see it, nothing showed up on the dash. After I cleared that out, it went back to boosting again, but then this time was boosting all the way up to 25 psi (I'm GMS1), maybe farther idk I let out, and I've been seeing less vac than normal too, showing up around 18-11 idling in neutral. I assume there's a boost leak involved, but I didn't see anything wrong, though I really don't know what to look for. Ideas?
Old Oct 6, 2011 | 07:17 PM
BozickA's Avatar
Check your lower charge pipe there is a bolt holding a bracket on that is to long and will poke a hole into it. You will have to look from underneath the car.
Old Oct 6, 2011 | 07:26 PM
TommyP's Avatar
AWD > FWD
I couldn't really tell, I can't get under the car far enough to look, I can't jack it up at home.
Old Oct 6, 2011 | 07:30 PM
Kyle4236's Avatar
couldnt that be a map sensor or a waste gate issue?
Old Oct 6, 2011 | 07:31 PM
BozickA's Avatar
Or take your lower and upper map sensors out and make sure they are not covered in oil. You might be able to reach down and under that charge pipe from the top and feel for the hole if it is there. There is a TSB on that charge pipe.
Old Oct 6, 2011 | 07:35 PM
TommyP's Avatar
AWD > FWD
ya I was able to get a look at it, I can't really tell if there's a hole there yet or not, but there certainly is an indent.
vahdyx's Avatar
What are your mods?
Old Oct 6, 2011 | 07:36 PM
TommyP's Avatar
AWD > FWD
K&N intake, forge bpv, catless dp, GMS1
I'm gonna see if they can squeeze me in to get the car on the lift tomorrow at work. I was hoping to get tuned and dyno this weekend, but if this isn't an easy fix I guess not
Old Oct 6, 2011 | 07:43 PM
TommyP's Avatar
AWD > FWD
oh and I should mention once I got off the highway (all this happened in about a 10 min drive on the highway), it went back to boosting normally, stopping around 21-22, and had ~18 vac. Tempermental bastard.
Old Oct 6, 2011 | 07:48 PM
SSlobalt's Avatar
That code does generally mean a boost/vac leak. Your best bet would be a boost leak test, but I understand that most people don't have the resources (air compressor/regulator) to run one.
Old Oct 6, 2011 | 07:49 PM
TommyP's Avatar
AWD > FWD
ya, nor have I done one before. With the weird levels of Vac that I've been getting that's kinda what I've been guessing, but I wanted to see what everyone else thought. And I'm sure my maf sensor could use cleaning as I've had a K&N drop in on the car since I got it (didn't know it had it till I got an intake), and now have a new K&N Filter, so it wouldn't be all that surprising if there was oil on it.
Old Oct 6, 2011 | 08:05 PM
TommyP's Avatar
AWD > FWD
Was out checking around the car some more, definitely something off with it. You could year the DI tick like normal, but every so often it would pick up and tick REALLY fast for a few seconds, and sound like the idle died down a bit. I did the old hold a socket extension up to the motor and listen trick, and you could hear the middle left injector and intake manifold port were FAR louder than the other two. Definitely gonna have the mechanics at work check the car out some more at work.
Old Oct 6, 2011 | 08:16 PM
Sox-Fan's Avatar
Got Brakes?
Tommy the symptoms are pretty similar to what my dealer just had to fix on my car. The tang that holds the MF sensor plug in had go broken when they replaced the air filter. I guess not sitting in there really tight was causing inconsistencies reading the MAF? Anyway, they had to replace the plug yesterday and it smoothed the car right out. It was definitely weird. Drove it home Tuesday night it had huge boost and whistled like it had a boost leak. Wednesday morning it was like perma cat warmup, then suddenly limp mode, until I restarted it, then it was down on power then it was fine. Kind of all over the place.
Old Oct 6, 2011 | 08:22 PM
Omnigear's Avatar
^this?
Old Oct 6, 2011 | 08:23 PM
ramrod1337's Avatar
Who installed your gms1?
Old Oct 6, 2011 | 08:29 PM
TommyP's Avatar
AWD > FWD
Originally Posted by Omnigear
^this?
Most likely, I've cleaned it once and the upper one is likely covered again, can't really get to the lower one. Need to get a catch can
a dealership local to me, haven't had any issues until recently, had it for over a year and a half.
Old Oct 6, 2011 | 08:33 PM
ramrod1337's Avatar
Mines done it twice both times right after leaving speedway in the morning, some of the electrical tape was coming off on the mad sensor on the cold side and it was rubbing the ac lines just something to look at
Old Oct 6, 2011 | 08:34 PM
TommyP's Avatar
AWD > FWD
Thanks I'll keep that in mind, I'll be looking at it myself while it's on the lift.
Omnigear's Avatar
take it back to the dealer n tell em the problem while its still under warranty
Old Oct 6, 2011 | 08:36 PM
TheBoss8688's Avatar
A lot of times the gms1 sensors pull up on the side without a bolt and leak
Old Oct 6, 2011 | 08:37 PM
ramrod1337's Avatar
Dealer isn't going to know what to do and the cars not going to act up or throw a code while they have it so they'll give it back saying there's nothing wrong this is a common problem with gms1
Old Oct 6, 2011 | 08:38 PM
TommyP's Avatar
AWD > FWD
I work at one, so I got that covered it'll be there 8am tomorrow, unfortunatley so will I for 9 hours
Old Oct 6, 2011 | 08:39 PM
BozickA's Avatar
What dealer are you at?
Old Oct 6, 2011 | 08:40 PM
TommyP's Avatar
AWD > FWD
Stadium GM in salem
Old Oct 6, 2011 | 08:41 PM
BozickA's Avatar
Ohh I am a tech at toyota in boardman didnt know if you were right up the street at weeny chevy
