Having some trouble setting up Interceptor shift light
Old 10-20-2013, 01:20 PM
cw383's Avatar
. I have dual interceptors, when setting up shift lights to come on both gauges, do I choose P1 only, P1 and P2, or P1 or P2. Seems obvious I should do P1 and P2, but it isnt working. Anounciator is on, and I was using RPM as the setting and above. Im trying to use 1500 RPM as a test, and I'm unsure how to enter that on the LNF type Interceptors (I think the LSJ and LNF cars use different gauges). Tried playing and searching, just cant seem to get it to work.
Old 10-20-2013, 01:30 PM
Got Brakes?
Sox-Fan's Avatar
Only P1. You're using one paramater. RPM. 1500. above.
Old 10-20-2013, 05:22 PM
cw383's Avatar
Sox, you are the man! I was getting frustrated with the damn thing. Turns out it was a rogue decimal point in the next to the last spot. I wasnt even considering I could just change it to a zero. Works perfect now. Much thanks!
Old 10-20-2013, 05:46 PM
Got Brakes?
Sox-Fan's Avatar
That decimal got me at first too.
RaginChopsuey
10-27-2015 01:27 PM
dennis69
10-20-2015 04:49 PM
OrangeCoba
10-01-2015 10:00 PM
09-26-2015 06:44 PM
Quick Reply: Having some trouble setting up Interceptor shift light
