Headed to Track Tonight!
Old Aug 14, 2010 | 04:47 PM
1SLOLT1's Avatar
Taking the Cobalt out to Sacramento Raceway tonight going to see what kinda numbers i can pull this time now that I have the GMS1 and Catless DP. I ran 14.0 stock.
Any guesses on what my new times will be?????
Old Aug 14, 2010 | 05:16 PM
Kildore's Avatar
13.5-13.7
Old Aug 14, 2010 | 07:40 PM
1SLOLT1's Avatar
Originally Posted by Kildore
13.5-13.7
At the least
Old Aug 14, 2010 | 08:18 PM
Kildore's Avatar
With out a tune for the DP and on street tires.. stock conti's?? I will stand with my 13.5-13.7 depending on the temp and such.. more towards a 13.7 due to it being August.
Old Aug 14, 2010 | 09:12 PM
1SLOLT1's Avatar
Yeah stock tires its about 90 degrees out
So far I ran 13.7 @ 108mph
Old Aug 14, 2010 | 09:26 PM
Kildore's Avatar
Lucky.. its been close to 110 here. lol.. so i dont go to the strip untill November.
Old Aug 14, 2010 | 10:39 PM
1SLOLT1's Avatar
Fastest trap speed was 109.664 mph
Old Aug 14, 2010 | 11:20 PM
Kildore's Avatar
I should have said degrees outside... lol.. its been freaking hot out! not good turbo weather.
Old Aug 14, 2010 | 11:24 PM
1SLOLT1's Avatar
I knew what u meant
Old Aug 14, 2010 | 11:26 PM
Kildore's Avatar
I knew what u meant
Oh.. ok
Old Aug 14, 2010 | 11:38 PM
RyRidesMotox's Avatar
Was that 13.7 your best pass all day? Thats pretty darn respectable for just street tires and a pretty much stock car.
Old Aug 15, 2010 | 12:04 AM
1SLOLT1's Avatar
Yeah so far. its a bit cooler out now I'm going to run a few more passes to see what I get
Old Aug 15, 2010 | 02:00 AM
T-Man's Avatar
That's pretty damn good man! Hopefully you're able to cut a decent 60' and hit a 13.5-13.6.
Old Aug 15, 2010 | 12:13 PM
1SLOLT1's Avatar
I need drag radials so I can launch off the line better. Also everytime I NLS to 2nd I spun all the way threw to 3rd gear I lowered my tire pressure down to 26 psi still was bad. I need to get some tranny mounts
Old Aug 16, 2010 | 10:10 AM
recklessnova's Avatar
use footballs it will help a lot on the 1-2 shift
Josh
Old Aug 16, 2010 | 10:59 AM
Josh
Nova I dig the sig, Two Lane Blacktop. That Chevy was badass.
Chevy: with a little work this thing could be really fast
Pontiac: Its fast enough
Chevy: It can never be fast enough
Footballs really? Hey whatever works right.
Old Aug 16, 2010 | 11:48 AM
1SLOLT1's Avatar
Josh
Football's?????? Do I dare ask??
Old Aug 16, 2010 | 11:51 AM
umrdyldo's Avatar
it's getting common. Just deflate some footballs, inflate in the rare suspension to taste and launch it.
Helps front stay planted a lot.
Old Aug 16, 2010 | 12:16 PM
1SLOLT1's Avatar
I'm going to take it you meant rear suspension and are you saying to install them inside the rear springs and inflate them??
Old Aug 16, 2010 | 12:19 PM
Terminator2's Avatar
Wow, that is a very high trap speed for a stock stage 1 tune. Most I have seen are running 104-105 mph. Then again some have trapped 104 MPH stock and some 98 MPH stock.
Old Aug 16, 2010 | 12:21 PM
EXsoccer1921's Avatar
yes get the peewee footballs. regular size wont fit lol. deflate them and stick them inside the rear spring, then inflate them. make sure they're both at the same psi
Old Aug 16, 2010 | 12:23 PM
wantedSS/TC's Avatar
106-107 seems to be the avg from what I've seen.
I've trapped 104.5 stock. Impressive in my book for a car that was completely stock at the time - I'm also a light guy too
Old Aug 16, 2010 | 12:27 PM
Billy Baldone's Avatar
If you are trapping almost 110 now on street tires,you should be a 13.0 car.You need to learn how to launch better on street tires,about 2.1 should get you there.Drag radials aren't going to help you much if you can't launch better without them
Old Aug 16, 2010 | 12:35 PM
CudaJoe's Avatar
Me too!
Old Aug 16, 2010 | 12:39 PM
^^ BS!
You're trapping 102. I've seen it in person
