help
Old May 23, 2011 | 03:42 PM
DerekDTP!'s Avatar
help
Just driving normal.. Alll the sudden CEL comes on.. Only boosting 16-17lbs.. Any ideas? Boost leak?
Old May 23, 2011 | 03:44 PM
BartSS's Avatar
yup somewhere....
Old May 23, 2011 | 03:47 PM
DerekDTP!'s Avatar
And only 7lbs on stock tune
Old May 23, 2011 | 03:54 PM
BartSS's Avatar
then yeah car is in limp mode. If youre on stock IC check the endtanks and if you got aftermarket chargepipes check all the connections
Old May 23, 2011 | 04:03 PM
umrdyldo's Avatar
first tell us the code.
Old May 23, 2011 | 04:08 PM
DerekDTP!'s Avatar
Scanner reads, system lean bank #1, system lean bank #2
Old May 23, 2011 | 06:46 PM
importkiller's Avatar
humm, that does not sound like a leak to me. My leak was brining up MAF and MAP sensor codes.
Old May 23, 2011 | 07:28 PM
DerekDTP!'s Avatar
Well now its boosting fine.. Idk maybe a computer freak out?
Old May 23, 2011 | 07:45 PM
AndrewSS/TC's Avatar
Maybe conditions caused it to swing lean for just enough ime to throw a code. Clear or and see if it comes back
Old May 23, 2011 | 09:22 PM
DerekDTP!'s Avatar
idk its wierd.. was running fine all day.. i look down and theres a CEL.. only boosting 15lbs with the tune, and 5-7lbs stock tune.. out of no where it was boosting fine, the CEL was still there, came out and started it up, running up to the store and it gone and everythings running fine...... wiiieeerrddd.. it was 105 degrees out today lol..
Old May 23, 2011 | 09:26 PM
Chevycobaltss3's Avatar
A boost leak or vacuum leak can cause a lean condition.......
Old May 23, 2011 | 09:44 PM
DerekDTP!'s Avatar
but now everything is running fine?
Old May 23, 2011 | 10:02 PM
SSlobalt's Avatar
Boost leak.
Old May 23, 2011 | 10:05 PM
Could easily be a loose coupler. ..
Old May 24, 2011 | 09:33 AM
BartSS's Avatar
It could be a MAP sensor going bad. It will go back and forth for a while then just stay in limp mode
Old May 24, 2011 | 09:37 AM
BooSSted's Avatar
You'd hear a boost leak, and they don't mysteriously fix themselves.
Could have possibly been a misfire or something that cleared itself up? I dunno...
Old May 24, 2011 | 09:39 AM
cmatthewb101's Avatar
You sure? It's a Cobalt. The retarded child of Corvette inbreeding. Anything is possible.
Old May 24, 2011 | 11:56 AM
2010redrocket's Avatar
Wouldn't a boost leak set a rich code??? I think that would be a sensor issue like bartss.
