Help ASAP
Old May 7, 2012 | 03:26 PM
Iturbo's Avatar
Help ASAP
Just installed my treadstone block off plate and I have the upper charge pipe w/ of course the hks ssqv. Hose is connected to the solenoid? When I boost and release...its a crazy flutter...It was more solid when I had the bypass still on
Solutions? Please
Here's my connection set up showing I have it going directly to the solenoid
http://youtu.be/XicWR68kytkhttp://s100.photobucket.com/albums/m...=VIDEO0032.mp4
Old May 7, 2012 | 06:05 PM
peachpuff's Avatar
Try connecting the bov directly to the manifold bypassing that solenoid, then plug up the hose that goes from the solenoid to the ic pipe.
Old May 7, 2012 | 06:26 PM
Iturbo's Avatar
Which ic pipe? Cold I'm.assuming?
Old May 7, 2012 | 06:27 PM
TommyP's Avatar
AWD > FWD
well this is the third time in the past month I've said this, get rid of the HKS, they always flutter dump like that.
Old May 7, 2012 | 06:46 PM
Iturbo's Avatar
So it is the hks? I ran the ssqv on my srt4 no problems. Never sounded that way
Old May 7, 2012 | 06:47 PM
sebleroux08/tc's Avatar
your going to flutter until you change the vac line routing and get a maf relocate , i have a tial q runs perfect now, like tommy p said hkss is hit or miss from what iv seen.
Old May 7, 2012 | 06:49 PM
TommyP's Avatar
AWD > FWD
yes it's the HKS, it's not built to be run a on a recirculated system such as ours. It's designed to be run on atmospheric setups like supras and 240s that run the old speed density tunes. Newer recirculated setups like the TC, or my Evo which is set up pretty much the same way, prefer bovs that run recirculated.
Old May 7, 2012 | 06:57 PM
Iturbo's Avatar
Okay so I'm safe though correct? This isn't a compression surge?
Old May 7, 2012 | 07:05 PM
Frogstofall's Avatar
You don't want it to chatter. Try the Synchroinc from Synapse/Vibrant. It's awesome.
Old May 7, 2012 | 07:13 PM
peachpuff's Avatar
Ya the hose goes from the solenoid to the cold side pipe where the tmap sensor sits, need to block it off since you won't be using the solenoid anymore.
Does it flutter at full boost or a couple psi?
I think one of the issues here is that the throttle plate on lnf's never really closes when you let of the throttle, it partially closes and doesn't give you the vacuum that you need to fully open the bov.
Old May 7, 2012 | 07:20 PM
FasterIsBetter's Avatar
I run the ZZP 50mm BOV here. No issues directly into the manifold. You will throw a cel for the bypass valve solenoid though. Those codes will have to be disabled and you should either run the factory by pass to the boost source on the lower charge pipe or get a by pass valve block off plate from treadstone.
Old May 7, 2012 | 07:22 PM
TheBoss8688's Avatar
T the BPV and the BOV together then direct the line straight to the top of the intake manifold bypassing the solenoid
Old May 7, 2012 | 07:29 PM
Iturbo's Avatar
I do have a block off plate from treadstone. And its fluttering at low and high boost. Idk I think if its not hurting the turbo or engine it really doesn't bother me. Ive read there has never been proof that fluttering causes a turbo to die. So Idk
Old May 7, 2012 | 07:48 PM
Every flutter is air that's trapped trying to escape (or at least that's how I understand it). Only option for it is to bang against the compressor wheel. Doesn't sound fun. I get a bit of low boost, light throttle chatter. Maybe just one single "ch" sound before it releases. Anything else and I would be replacing it.
Old May 7, 2012 | 08:02 PM
Iturbo's Avatar
Im in progress uploading 2 videos.
1 of the said flutter even at idle
2 of the connection I have and showing block off plate
Old May 7, 2012 | 08:17 PM
Iturbo's Avatar
BUMP FOR FLUTTER VIDEO
CLICK LINK ( photobucket ) let me know if something isnt right
Old May 7, 2012 | 09:18 PM
lol too much hose runnin everywere! the line that comes in at 12 oclock is the line to the lower charge 6 oclock is from thr lower boost solenoid then 9 is to the bov or bpv when stock intake mani is to the in to the other side of the lower boost solenoid . so what you wanna do to run one single line is block off the one from the lower charge pipe so the line at 12oclock then cap that side of the solenoid then remove the 9oclock line tuck those outta the way then capnthose two nipples aswell then the line from the intake manifold remove it aswell tuck it out of the then run one vac line from the intake mani to the bov and should be just dandy,just sure that boost solenoid all three nipples are caped if you need a pic let me know. i might wromg but im sure someone will correct me lol
Old May 7, 2012 | 09:40 PM
Iturbo's Avatar
Yeah can I get a pic lmfao
I was confused...I get your concept but mid way I was lost...and what would I cap them off with?
Old May 7, 2012 | 10:26 PM
I did it super ghetto just to see if it would work but I shuved bolts in 4 inch pieces of vac line then zip tied it to cap it for now pm me your cell number ill take a pic
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
