Help please!!!!!
Help please!!!!!
hey guys chris here, first off, it was great seeing everyone at the OC meet last month! ok heres the dilema, i have a Hahn CAI, HP tune and catless zzp downpipe as my modifications. it is POURING today in baltimore and i did hit several huge puddles that were unavoidable, but about 5 minutes later when i merging onto 695 in towson my car wouldnt accelerate like it used it. i figured i accidentally shifted into 5th so i went into 3rd, and when i give it gas, i hear a whine almost like a supercharger but sounds like its air. the whine occurs right when i would normally start getting boost. my RPD reads zero psi on the boost guage setting. i limped it back to my house and its in the garage now. does anyone have ANY ideas what this could be?
negative. found out the turbo is FUCKED. details to follow. returning car to stock now. if they warranty it ill be lucky. if not maybe a bigger turbo, odds are ill just get my Cobra.
anyone with ideas please shoot em my way
still figuring out how it got fucked. theres thick chunky oil all over the inside of the intake and charge pipes, were gonna change the oil and look for metal shavings to see if my block is proverbially, "fucked" as well. headed to salvo for oil.
The fact it happened after hitting puddles with your CAI>>>pulled water/debris into the intake and motor?
Nope not normally because it would have to make it through the turbo, hotpipe, IC, coldpipe, and up though the throttle body. It is possible to get water into the motor but more than likely the water is what messed up the turbo.
With complete hydrolock yes. If this happened right after hitting the deep puddles you almost certainly pulled in water. Not sure how it would screw up the turbo but if the engine farts big you could blow some rings..etc..sending oil all over the place. You said charge pipe had oil in it...HOT SIDE too? Then turbo was leaking oil into it OR>>>oil from motor farted back through IC into hot pipe. How does IC look?
Trust me, just get your Terminator.
Also, I've noticed that a few LNF's have had the same problem as you. Seems like it's becoming a common issue, I don't remember exactly what it is but you likely blew the #1 piston ring IIRC. My friend had the same exact problem. He went back to stock, got a new warranty motor, and traded it in for an evo. After he had that problem I sold mine and turned my toy car into my dd until I find something else to dd.
I saw a thread online a few years back about what water spray does to the fins on a turbo, it was funny! lol.
Whining Turbo is 9 out of 10 times a blown turbo! Ill help you get the used one on if you need help
again BYT for the clutch win, no pun haha. thank man ill let you know. give me a shout and we can talk about maybe flashing back to stock. i dont know if its worth it because i have the fix for 200 bucks.
UPDATE new GT35r is on and .... just kidding. new STOCK turbo is on and i have a boost leak somewhere. im tuned to 22psi but im only making 14 then rapidly dropping down to 7. 09whiteSSpsshh and i are going to try replacing the diaphram in the turbo and see if that was torn or something.
