Help! Who has upgraded clutch. Probs with my clutchmaster stage 3
Old Sep 2, 2009 | 01:24 PM
sporttintturbo's Avatar
Just had my clutch installed dealership is telling me they have no peddle on The clutch. Had clutchmasters stage 3 clutch and aluminum flywheel installed. Who has one? Who can help me I don't won't to have to put stocker that's not holding back in.
Old Sep 2, 2009 | 01:26 PM
Terminator2's Avatar
They need to replace the slave cylinder or bleed it properly.
Old Sep 2, 2009 | 01:29 PM
PrincessTurbo's Avatar
WOrds of wisdom .
Take your car to a clutch/transmission shop where they have techs who actually know wtf they are doing ..
Old Sep 2, 2009 | 01:36 PM
Someone else told me I might need a upgraded slave cylinder? Any insight on that? I'm clueless in the clutch department. Dealship said he has bled it properly. Why would the slave cylinder need replaced?
Originally Posted by PrincessTurbo
WOrds of wisdom .
I figured the big dealership I got my car from would be able to figure it out. That and there are special tool they have to get just to take the tranny apart. Regular shop would prolly rape me in labor and those stupid tools
I took it it to have sychros replaced under warranty. So install was only going to be 100 bucks.
Last edited by sporttintturbo; Sep 2, 2009 at 01:36 PM. Reason: Automerged Doublepost
Old Sep 2, 2009 | 01:39 PM
Crate engine depot has slaves for our trans. Just a good idea to relace it while you have it apart so you dont have to open it back up later. I dont think they bled it properly it probably has a big ole air bubble in there somewhere unless the cylinder is leaking or failed.
I am sure they might rent the tool if they are too stupid to get it to work
Not a whole lot of people here have upgraded the clutch do to this exzact reason .
Nobody really knows 100% without a doubt that these clutch kits work for our cars
I think a few people have the exedy and the other brands that are compatible .
You may ask them if they could try and do a "clutch" relearn with the tech 2 tool .
Since these cars are "drive by wire"
Old Sep 2, 2009 | 01:47 PM
Looked on that site couldn't find anything? Where did you find it or did you call? And is it a better one of just factory replacement
Negrita SS's Avatar
The clutch needs to be bleed with a vacuum pump if you pump bleed it you will be thier all day long if you pump it you **** it up the slave Do Not pump the clutch when bleeding
Old Sep 2, 2009 | 01:57 PM
Will suggest that but a question do any of you have an ugraded clutch or know someone who has the clutchmaster stage 3 installed? I'd like to get ahold of someone who has installed one. dealship thinks it's my clutch that's the problem
Old Sep 2, 2009 | 01:59 PM
I took my car to the dealer for an aftermarket clutch install
Old Sep 2, 2009 | 02:13 PM
What clutch and problems did you have?
Old Sep 2, 2009 | 03:32 PM
It was a joke ...
I'm just trying to keep your thread alive untill someone gets the answer you're looking for . A new clutch is in my things to do soon.
Next year is the clutch , turbo kit , maybe ported head and some internals fueling we will see .. I am still skeptical for reasons like your post for going any further . Allthough without people like you we wouldn't really get anywhere without you being the guinea pig for us all ..
Old Sep 2, 2009 | 03:44 PM
Haha yea I am the test dummy I work out of state for long periods of time so it's not like I need the car tomorrow. Company truck baby! But back on subject I got friends calling suoervisor they know at the dealorship to raise hell. Will keep you updated. I hope it goes right my dyno looked like a ******* rainbow. ******* stock clutch.it hit 295 hp and 355 torque and said I quit stop raping me.
Old Sep 2, 2009 | 04:53 PM
BartSS's Avatar
When I did a clutch in my civic the master cylinder went out. Its always a good thing to replace it when ur gettin an upgraded clutch especially if its gonna be stiffer
Old Sep 2, 2009 | 07:22 PM
Still waiting on dealership to call back. Had another guy I PM'D tell me someone with same setup needed a special adapter rod because his clutch was not engaging right. And he was going to make one so I emailed clutchmasters. I called once. they said they will be calling me back. I don't know of anyone with a actual install on one yet. So we will see where this takes me.
Old Sep 2, 2009 | 07:32 PM
Jn2's Avatar
Jn2
tranny shops are noamlly cheaper than a dealer, here a local tranny shop will install a clutch and flywheel for 350
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
