home brewed octane booster
Old 09-20-2009, 12:25 AM
fakameanrepresent's Avatar
http://www.evoxforums.com/forums/showthread.php?t=16920
i've been reading article on a lot of site such as those evo and subi
mixing 10% ish of TOLUENE in your gas tank can boost your octane rating. and i'm not really sure about the whole math and science behind this. but a lot of those evo, subi guys are coming out some great result with this toluene stuff which can be purchase from paint store. any more knowledgeable people please come out and chimp in, please. i want to understand this tolune stuff.
quote from qoute from wiki
Toluene can be used as an octane booster in gasoline fuels used in internal combustion engines. Toluene at 86% by volume fueled all the turbo Formula 1 teams in the 1980s, first pioneered by the Honda team. The remaining 14% was a "filler" of n-heptane, to reduce the octane to meet Formula 1 fuel restrictions. Toluene at 100% can be used as a fuel for both two-stroke and four-stroke engines; however, due to the density of the fuel and other factors, the fuel does not vaporize easily unless preheated to 70 degrees Celsius (Honda accomplished this in their Formula 1 cars by routing the fuel lines through the muffler system to heat the fuel). Toluene also poses similar problems as alcohol fuels, as it eats through standard rubber fuel lines and has no lubricating properties as standard gasoline does, which can break down fuel pumps and cause upper cylinder bore wear.
^ so from my understanding, a small doese of this toluene should not do any harm to our motor, or O2 sensor.
Old 09-20-2009, 12:28 AM
impulseballer's Avatar
yeah i saw a huge thread on every type you can use but i wouldn't **** wit it. have fun tho
Old 09-20-2009, 12:55 AM
yeah man i know, pretty much every forums talks about this toluene mix to get higher octane for cheap. anyone want to chimp in more?
Old 09-20-2009, 12:57 AM
from what i heard it's not that safe etc....i wouldn't want to **** with my car like that.
Old 09-20-2009, 01:00 AM
NS06G5's Avatar
toluene is powerful stuff, if you decide to use it, use in well vented area, with rubber gloves, and keep it off paint, same as most everything else.
All I can tell you, is we use toluene as a slovent on airplane parts in watered down doses. I've seen this stuff in pure form eat through kevlar, kevlar/cf combined fabrics like butter, along with alum rivets, and alum outter skins. It's just like methenol(gas line antifreeze), in small doses it should be ok.
But do your homework, and get the ratio's right, cause that would be a hell of a expensive fix. If your engine is still under warranty, I wouldn't even consider this, there are other proven octane boosters out that you'll get the samething with.
Old 09-20-2009, 02:54 AM
mkriebs's Avatar
I wouldn't trust it. I know people have been doing this since the stone age... But think of it this way. Toulene is basically a paint thinner (a very strong one as evidenced above). So, basically, you are thinning out your fuel. Fuel does have some lubricant properties to it, so IDK if I would feel too safe and confident about thinning my fuel. Just my 2 cents though.
Old 09-20-2009, 03:06 AM
YaKkO's Avatar
i fukin love your sig bro!
Old 09-20-2009, 03:07 AM
mkriebs's Avatar
Thanks, lol. One of my buddys that knows I am a forum ***** sent me that to use, lol.
Old 09-20-2009, 01:41 PM
^haha, it is indeed funny.
Old 09-20-2009, 01:49 PM
drewbroo's Avatar
I just run Half a tank of 91 + Half a Tank of E85. Creating E47.5.
Old 09-20-2009, 04:58 PM
^interesting
Old 09-20-2009, 05:04 PM
dunit121's Avatar
idk sounds way to dangerious for my liking ... kinda like running nos in a bran new car... but im subd to learn more about this stuff
Old 09-20-2009, 10:39 PM
mkriebs's Avatar
I tried that, and you wouldn't believe the amounts of knock I got. I had to run the car to empty before I could get it to stop being a bitch about it.
Old 09-20-2009, 11:11 PM
drewbroo's Avatar
I got no knock, and surprising great hot weather performance.
Old 09-20-2009, 11:31 PM
Chandler's Avatar
having owned a heavily modded wrx , and being around the boards for more than 8 years, I would suggest you not do this.
Old 09-20-2009, 11:37 PM
drewbroo's Avatar
Who are you suggesting not do this, I with E85/91 Mix or the op with toleune?
Old 09-21-2009, 12:18 AM
IsItFast?'s Avatar
If you mix e85/91 don't tune off the mix or tune very safely. e85 isn't perfectly 85% ethanol, it can vary by as much as 10% fillup to fillup (if not more), combine that with the fact you don't know exactly how much gas to ethanol you have mixed in your tank, and you have no idea what mixture you are tuning for. This is the reason "flex fuel" vehicles use a sensor to determine the amount of ethanol in the mix. The sensor uses dielectric measuring principle which basically means it measures the conductivity of the fuel - ethanol conducts better than gasoline.
Oh and we do have a lot of aluminum in our fuel systems - including the engine itself - See the above comment about aluminum and Toluene. Not a good combo for longevity.
Old 09-21-2009, 12:28 AM
drewbroo's Avatar
I have braided steel fuel lines, and all vehicles manufactured after 1995 have fuel systems that can support E85 in just E85 form. (As long as you up the injector size) Its all smoke and mirrors, the sensors don't do anything but keep the fuel mixture rich, if you tune for that you gain power. I have been using E85 in all my cars since 2006, my 422WHP 20G 9-3 ran on E85, you just need bigger injectors for non DI vehicles. I usually use steel braided fuel lines for a safeguard factor.
Old 09-21-2009, 12:38 AM
HunterKiller89's Avatar
someone needs to work on their math skills...lol
half of 85 is...?
unless your factoring in the "our gasolines may include up to 5% ethanol by volume" thing...
Old 09-21-2009, 12:46 AM
Chandler's Avatar
The Toulene, no bueno.
Old 09-21-2009, 09:37 AM
drewbroo's Avatar
half of 85 is...?
Its up to 10% E
85 + 10 = 95/2 = 47.5
Old 09-21-2009, 12:23 PM
383_Stroker's Avatar
I've used the toluene octane booster when I ran a gas engine in a "pump gas" class. It worked in that application.. I've never tried it on a street car though.
Old 09-21-2009, 03:17 PM
Its up to 10% E
lol fair enough.
every day im on these forums, i want forged internals more and more...
Old 09-21-2009, 04:08 PM
New Creation's Avatar
Toulene will increase the octane rating of gasoline fuels. The octane of toulene is about 112. However, a better material would be xylene. It has an octane rating of 119 and has more enery per gallon than toulene. A good mix would be 3 gallons of xylene and 7 gallons of premium gasoline for an octane rating of about 104. You will never have a cleaner fuel system. The last time I checked, the price of xylene was about the same price as premium gas. DO NOT GET XYLENE ON YOUR FLESH - IT IS A KNOWN CANCER CAUSING AGENT - SO IS TOULENE. DO NOT GET IT ON YOUR PAINT FOR IT WILL REMOVE IT.
Old 09-21-2009, 04:15 PM
drewbroo's Avatar
+1 on XYLENE
Quick Reply: home brewed octane booster
