How do I scan the OEM wide band with HP Tuners?
Old Dec 4, 2008 | 02:56 PM
marcusicp's Avatar
I have had HP Tuners for a while now for other cars and I just got around to trying to log my Cobalt. I can't seem to get the AFR to scan or log. What do I need to do to set it up? I am a novice with this software other then plugging it in and scanning/logging. Any help would be appreciated.
Old Dec 4, 2008 | 02:57 PM
originaladrian's Avatar
a wideband sensor
Old Dec 4, 2008 | 03:06 PM
marcusicp's Avatar
Originally Posted by originaladrian
a wideband sensor
I am not sure what you are trying to say but if I understand you correctly you are assuming I don't have a wide band O2. Well, the LNF cars all have wide band O2 sensors. I just need some help scanning it with HP Tuners. I know others have done it and I need them to show me how.
Old Dec 4, 2008 | 03:54 PM
SSpdDmon's Avatar
Download the config (.cfg) file and put it in the appropriate folder. Ask tuning questions in that forum and you'll get a quicker response.
http://www.hptuners.com/forum/showthread.php?t=9331
Old Dec 4, 2008 | 04:17 PM
marcusicp's Avatar
What config file do you recommend? I have tried 2 or three different ones already and none of them will scan the WB O2. Did you have to do something to make HP Tuners see the WB O2? Would you be willing to send me the config file that you are using? PM me if you want my email.
Old Dec 4, 2008 | 04:57 PM
08BlackSS/TC's Avatar
PM me with your email and I'll send you my config file and I'll take a snapshot of the PID you need to have to get it to work
Old Dec 4, 2008 | 04:58 PM
06black's Avatar
hi-res narrow band, good, but not bitchen.
none the less you call it up in the table set, then add it to you chart, histogram, ect.
Old Dec 4, 2008 | 06:28 PM
marcusicp's Avatar
PM sent!
What's the difference in a wide band and a high-res narrow band? Would it be worth picking up a "real" wide band for the turbo cars?
Old Dec 5, 2008 | 08:04 AM
06black's Avatar
PM sent!
resolution and much response!
you bet your ass it would be.
another nice feature of a normal wideband is the ability to tie it into HPT and log that info along with the car during pulls.
Old Dec 5, 2008 | 09:07 AM
Bryan, the SS/TC come with a wideband from the factory
Old Dec 5, 2008 | 09:57 AM
06black's Avatar
say it with me....
"hi-res narrow band"
vary Ls-1 ish,
cars that have actual factory wideband sensors are more economy based performance cars, the new honda accourd V6 for example.
runs 2 lab grade widebands, a set up from a dealer will run you well over the $1000 mark.
the OE LNF stuff is good, not AM WB quality, but good. Thanks in large part to the 32B sectioned processor, but none the less, nice to have.
Old Dec 5, 2008 | 10:10 AM
SSpdDmon's Avatar
say it with me....
Look in the mirror and repeat after me....
"I can be wrong from time to time."
http://www.urbanracer.com/articles/a...3039&print=yes
Emissions controls:
close-coupled catalytic converters, Quick-Sync 58x ignition system; returnless fuel rail; wide-range O2 sensor
That comes straight out of a document I'm looking at that GM released to the press.
http://media.gm.com/
Old Dec 5, 2008 | 12:41 PM
06black's Avatar
god dam this iPhone.
I've tried to type a reply like 3 times now and it just gets laggy with the buttons and closed the program.
Once I'm back in the office I'll show u what I mean. Narrow band doesn't mean 1v range and wide band / ranges doesn't mean 5v range.
U need more then 1v for lamda calcs but the oe doesn't test out to 5v, goes to 3.x volts.
The bitchen widebands that we do emmision cal with report backbwith more then a 10v range.
This is why I use a normal wb on the lnf cars I tune.
The .2-.3 afr diff between or and am makes a big differance in safty and max power, also have the gauge display helps the driver check for safe afr's as weather changes.
Ballen.
I hate this phone more with every
Post i try to make.
Old Dec 5, 2008 | 12:48 PM
SSpdDmon's Avatar
Ballen.
Post i try to make.
I think you're confusing precision with band. AFAIK, the "band" in wideband refers to the range of AFR's detectable (i.e. some WB's are good for measuring AFR's of 7:1 to 22:1). The precision in which they report those AFR's (i.e. the range of voltage output they have) is a different story. If the sensor can accurately and consistently report to the hundreth, why wouldn't that be good enough?
Example...
Assume there's a 3v operating range. If the sensor's precision is accurate to the .xx hundreth, then you could have an equation such as:
AFR=(V*2)+11
...the net result being an accruate AFR (to the tenth) between 11.0:1 and 17.0:1.
I'd highly doubt that GM would spend the extra $$$ to set up the car with a WB and then cheap out on the engineering design and operation of the part.
Old Dec 5, 2008 | 01:02 PM
06black's Avatar
they dident spend more, or cheap out.
This is a new system that was developed to raise the mpg across the range, the new cafe std's are a bitch!!
It's just cool to have this on a performance car.
True oe approved widebands are huge money, part cost alone can answer this debate.
Old Dec 5, 2008 | 01:06 PM
Psykostevo's Avatar
Ballen.
Post i try to make.
Welcome to typing on a forum on the iphone. Worst part is that it never saves what you typed.
Or I also enjoy when it decides that it wants to freeze on the Backspace button and all you can do is sit and cry while you watch everything you typed get uncontrollably erased!
On the config file the WBo2 was mistakingly listed as EQ, but it is calculated as Lamda so it's labelled wrong. Just multiply that times the Stoich AFR, which actually isnt listed in the HPT file :-( I have seen these cars idle pretty lean, and not always near 14.7
Old Dec 5, 2008 | 01:24 PM
06black's Avatar
so I'm not the only one with the backspace button of death!!!!!
Any who, if u look at the resolution count, it's much more defined/ updated more around the stoic-to-lean cruse area of the lamda scale.
Lamda rocks tho, make more sience then afr.
Old Dec 6, 2008 | 03:12 PM
SSdan's Avatar
I hate when the god damn backspace freezes and deletes everything.
no_ss
Oct 18, 2015 11:58 PM
2009blackSS
Sep 30, 2015 05:57 PM
Trav3480
Sep 28, 2015 02:46 PM
z28addiction
Sep 28, 2015 12:03 AM
jas09ss
Sep 26, 2015 01:06 PM
