How to gut cats?
Old Apr 19, 2013 | 10:10 PM
cranemaster's Avatar
How to gut cats?
Just curious how people went about doing this? I want it to look stock from the outside for any visual checks, but be free flowing, do you just kock out all the cat material with whatever will work and fit?
Thanks!
Old Apr 19, 2013 | 10:15 PM
From just your thread title I thought you meant the kind of cats that go meow.
Old Apr 19, 2013 | 10:16 PM
ssyellow's Avatar
That^
Personally I would just buy an aftermarket down pipe. Bigger, better flow, made for performance, etc. Plus if you have an LNF if I remember correctly you have two of them. Get a pipe or something I guess, never have really done it hah.
zerosk8ter83's Avatar
lol same
buildmeanempire's Avatar
In for... DAMN! Not the right kind of cat...
Old Apr 19, 2013 | 10:19 PM
inb4riceburner.
Old Apr 19, 2013 | 10:21 PM
Melon's Avatar
Lol totally thought the same as u guys!
Old Apr 19, 2013 | 10:25 PM
kzak104's Avatar
this is a car forum and you do know that cat means catalytic converter?
anyways i would just get a new downpipe and swap them whenever need be, or get an aftermarket downpipe with a high flow car.
Old Apr 19, 2013 | 10:27 PM
That's a good point, but there has been a lot of strange threads lately ^
Old Apr 19, 2013 | 10:57 PM
Yeah I just found out from a police friend it's actually legal to be catless .. So il proba ly just swing for catless race pipe then finally a tune!!
Old Apr 19, 2013 | 11:00 PM
Silverbullet33's Avatar
^ in saskatchewan? id love to know how they allow catless cars there, Canada is a PITA for emissions for any car!
Old Apr 19, 2013 | 11:06 PM
This, so you might want to check the motor vehicle stats for your province as that does not sound right. Because you can't get away with out one in BC
Old Apr 20, 2013 | 03:42 AM
southal cobalt's Avatar
take a long metal rod and just keep banging it into the inside of the pipe. you can loosen some of it up by hitting the outside of the pipe with a rubber mallet. after about 30 minutes, you should have that **** all over the floor
dont ask how i know lol
Old Apr 20, 2013 | 04:02 AM
Omnigear's Avatar
the cat is toxic..... use protection
Old Apr 20, 2013 | 08:18 AM
09BlueBaltSS's Avatar
I'd imagine it's just like a rabbit. Wait what.....
Old Apr 20, 2013 | 08:32 AM
turbosmart4's Avatar
U hit them in the head , then lay them down on their belly and grab an exacto knife.
Old Apr 20, 2013 | 09:10 AM
There is a downpipe thread on here where someone tested all kinds of combos. Short of buying an aftermarket Catless downpipe the best performance was cutting open the stock cats and welding in a pipe after you gut them. Looks factory but won't pass a sniffer obviously
Old Apr 20, 2013 | 09:22 AM
JapEatr's Avatar
South Central *********
I use a 5.5" skinning knife. Damascus steel, ironwood handle.
I typically start at the inner thigh and work my way down to the cemterline. Then i just cut the main line and drop all the goods out.
Old Apr 20, 2013 | 10:24 AM
DirtyBalt09's Avatar
Just use a pipe some gloves to pound out the material. I'd use a breather mask or a bandan or something across you mouth and nose. Get new gaskets Also.
When I bought my car cats were hollowed out by the previous owner.(I bought it with 4 k) :/
It will throw a code obviously unless tuned out. The problem with hollowing out the stock pipe is it is still pretty restrictive even with no cats due the the crush they put in the pipe also. The pipe is 2.5 and crushes down to 2" in a spot. That bottle neck makes it better to just get a catless pipe IMO.
Old Apr 21, 2013 | 12:58 AM
Harmonically's Avatar
Whatever you do, see if you can find someone who has the same setup. I threw a catless x-pipe on a v8 car I had. Sounded awesome until I realized it droned like an army of killer bees @ 70 mph... so yeah, make sure you're ok with it being super loud.
Old Apr 21, 2013 | 01:01 AM
I think they have cook books on how to gut a cat in North Korea
Old Apr 21, 2013 | 01:12 AM
They ate all the cats. Now it's how to gut and cook your neighbors.
Old Apr 21, 2013 | 01:15 AM
That would be South Koreas problem ^
Old Apr 22, 2013 | 09:17 AM
umrdyldo's Avatar
I just did this.
Go buy a 2.75 inch piece of pipe from O'Reilly or similar.
Take that pipe and stick it in the end of the downpipe and push it through the cat.
I actually just put on gloves and pushed it in while doing a screw type action. It will go through. Take about 10 -15 min. Your arm will get tired.
Wear gloves. I did it on a lift.
Supposodly, doing it this way you will have a 2.75" hole in the cat, and material on the edges that will heat up and seem like it's working to the average joe.
EDIT: You only need to do the rear cat. It was found that gutting both causes a loss of low end torque. It's nice just gutting the rear because you don't have to remove the downpipe just unhook the rear.
Old Apr 23, 2013 | 03:47 PM
tomj77's Avatar
First u need to kill it, then u need a sharp knife.
