hpfp Install help???
Old Feb 12, 2020 | 12:34 PM
1sickcobalt's Avatar
i just ordered the pump and gasket,hoses and orings but im stumped on installing this.ive been watching this video and i see they take out the cam bearing? In the other videos i see them pull the pump off and then reinstall the pump without taking the cam bearing out.yes i have checked past threads but nobody really gives an exact answer.im also going by this video from bosch?
Old Feb 12, 2020 | 01:25 PM
tomj77's Avatar
Fuel pump cam roller only needs to be replaced if worn. Take it out, check it, replace if needed , if not put back in. The pump itself is 2 bolts, pretty easy install.
Old Feb 13, 2020 | 01:12 PM
Ok cool thanks Tom for the response.
Old Feb 13, 2020 | 09:44 PM
C0balts5's Avatar
They say that the fuel line is one time use but I just snugged mine up good and haven't had issues. Just tighten the bolts down evenly. I didn't even know about The replacement piece for the cam lobe until after fact.
pt5457balt
Nov 4, 2025 11:18 AM
boostbalt
Aug 8, 2014 09:11 PM
derekhollister
Forced Induction
12
Jul 17, 2013 05:43 PM
firebal
Jul 3, 2012 10:31 PM
Mendomar06
Dec 6, 2011 10:50 PM
