hpt question
Old Apr 5, 2010 | 05:53 PM
black08ss's Avatar
hpt question
Has anyone figured out a way with hp tunes to change the launch control so it'll launch off boost, like a two step instead of just a pre revlimiter like basickly what it is now
Old Apr 5, 2010 | 06:08 PM
tom.g's Avatar
As far as I know the answer is no.
Old Apr 5, 2010 | 06:19 PM
black08ss's Avatar
what are some 2 step options m2mb?
Old Apr 5, 2010 | 06:25 PM
BLAZIN07SS's Avatar
I'm too JDM for you
your car has a 2 step from factory. what you are thinking of is an anti-lag set-up
Old Apr 5, 2010 | 06:31 PM
black08ss's Avatar
no a 2 step builds boost anti lag retards the timing. we have a pre revlimitter aka launch control
Old Apr 5, 2010 | 06:32 PM
BLAZIN07SS's Avatar
I'm too JDM for you
look up what a 2 step is
Old Apr 5, 2010 | 06:45 PM
black08ss's Avatar
what is ur definition of a 2 step? and i found out from a buddy of mine that n2mb makes them for the sc and they are about to release them for the tc
The 2-Step Launch Control modulates the ignition by cutting power to individual ignition coils to hold the RPM you want to launch at. The turbo will spool up while you do this. (straight from n2mb)
Old Apr 5, 2010 | 06:51 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you know what the definition of a two step is right? all it is, is a secondary rev-limiter. therefore your factory car uses a two step.
Old Apr 5, 2010 | 06:53 PM
black08ss's Avatar
a 2 step also builds boost omg i didnt think this was a hard concept but i guess it is
Old Apr 5, 2010 | 06:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
haha no your just wrong. that is not a 2 steps main intention(FYI they are meant for consistent launching). they build minimal boost compared to a true anti-lag set up.
Old Apr 5, 2010 | 07:01 PM
black08ss's Avatar
so i guess me and n2mb is wrong well ok whatever you say chiefly
Old Apr 5, 2010 | 07:02 PM
BLAZIN07SS's Avatar
I'm too JDM for you
how much you wanna bet you only see like 5-6psi? maybe, if that. that tiny hairdryer on the LNF does not need to build crazy boost at the line. it reaches full spool by like 2,500rpm anyway
Old Apr 5, 2010 | 08:21 PM
Jaxon's Avatar
A real 2 step cuts timing and will built boost. The launch control is basically just a rev limiter in neutral. You can change your neutral rev limiter all you want to whatever you want. The launch control uses the brakes and such too, screw that, just what I need when I'm trying to go WOT is 1-4 out of 4 brakes engaging. Launch Control and rev limiters are fuel cut not timing cut. Thats why a WOT box sounds different than launch control.
Old Apr 5, 2010 | 08:26 PM
BLAZIN07SS's Avatar
I'm too JDM for you
that is not a 2 steps intention. however part of antilag requires the use of a 2 step
Old Apr 5, 2010 | 08:44 PM
JAYNO20's Avatar
maybe its just me, but I am going to listen to what the guy with 8,236 posts says versus the guy that has 67. Odds are good Blazin probably knows his ****.
Old Apr 5, 2010 | 09:24 PM
pantherqs's Avatar
poasting is srsly srs and automagically gives credibility to everyfin.
On a related note, this entire thread makes my brain hurt so much.
Old Apr 5, 2010 | 09:27 PM
Jaxon's Avatar
Lol panther, I completely agree. I am not a post ***** and dont post here much mostly because I don't have a cobalt. I come here because the HHR forums are not much help when it comes to performance due to the fact they are HHRs.
Old Apr 5, 2010 | 09:31 PM
BLAZIN07SS's Avatar
I'm too JDM for you
whether you choose to believe me or not, i don't care. lol. this is common knowledge that is constantly confused. research it and you will see what is correct for yourself
Old Apr 5, 2010 | 09:50 PM
09CobaltSS1's Avatar
higher post counts = a bigger dick and higher IQ
it's a fact.. look it up
Old Apr 5, 2010 | 10:23 PM
blackrocky's Avatar
blowdryer? that had me dying lmao
Old Apr 5, 2010 | 10:46 PM
JAYNO20's Avatar
Uh I never said that, odds are good if you are posting all the time you are going to come across correct information more often than if you are just going by what someone told you.
Old Apr 6, 2010 | 02:53 AM
pantherqs's Avatar
Needle in a haystack, and this forum is a pretty big ******* haystack.
Old Apr 6, 2010 | 04:25 AM
JAYNO20's Avatar
Good point.
Old Apr 6, 2010 | 08:19 AM
BLAZIN07SS's Avatar
I'm too JDM for you
so did you guys do your research and find out i was out i was right?
Old Apr 6, 2010 | 09:14 AM
BYT*SS*TURBO's Avatar
Ill bet you $1000 right now you are 100% wrong. Ask me how I know
