hptuner question
Old Sep 10, 2011 | 09:52 AM
KennyS212's Avatar
hptuner question
What is the difference between the spark advance tables and the optimum spark table in the hptuner program??
Thanks
Old Sep 10, 2011 | 10:23 AM
Omnigear's Avatar
one advances the other does not
Old Sep 10, 2011 | 02:42 PM
T-Man's Avatar
Thanks
To the best of my knowledge, optimum tables are used for torque calculations along with other internal ECU calculations.
Spark advance is your ignition timing.
Do yourself a favor and leave the optimum spark tables alone, get some more knowledge under your belt and experiment later.
Old Sep 10, 2011 | 05:29 PM
cobaltssoverbooster's Avatar
dont change the optimum tables they are set for optimum spark at a solid state to help calculate load/toruqe.
you adjust the four spark tables to get your actual spark
Old Sep 10, 2011 | 09:12 PM
KennyS212's Avatar
i wasn't planning on changing the optimum spark tables, (especially since i didn't know what they were lol) i was just wondering what they were.
Thanks
Old Sep 11, 2011 | 11:05 AM
BYT*SS*TURBO's Avatar
Yea, def don't touch the optimum spark table unless you really know what you are doing!
Just saw your other thread about the logging stuff, I recommend you read up on HP Forums on some of the how-to's, download the basic file loaded in the repository and then learn to MAF tune. From there the sky's the limit! But that will give you a good start and look at what a tune does on these cars, its pretty amazing the power you can pickup from tuning alone
Old Sep 11, 2011 | 04:11 PM
KennyS212's Avatar
Yea, lol. I'm learning still. I have my fuel trims dialed in perfectly. my long terms usually stay right at zero and my short is only a few % up or down. I'm working on my timing tables now. You want as much advacement as possible without getting KR correct?
Old Sep 12, 2011 | 12:45 PM
silverbullet08's Avatar
I would use factory timing tables then get a steady boost spike of 22-23psi ish then when you have the spike under control raise your timing until you start to see kr then back that area down about 2*
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
Adecker
Oct 20, 2015 09:46 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
