I hate installing the lower CP!!!
Old Apr 7, 2013 | 12:39 AM
JetLAGG's Avatar
Good lord the lower charge pipe a bitch to put on! Also, who ever put the car front bumper did a horrible JOB!!! Damn left side was put on wrong. Anyways, the problem that I'm having is with the clamp for the hose and putting the hose all the way down onto the plug for the lower charge pipe. Any tips for this?
I can't seem to find the right angle to get it down....
P.S. it's a hahn lower charge pipe.
Old Apr 7, 2013 | 12:58 AM
tomj77's Avatar
lower charge pipe is easy if u know how to do it, iv done it often enough I learned. lol use needle nose plyers. only thing that works to put that clamp on for me
Old Apr 8, 2013 | 07:25 PM
Frogstofall's Avatar
Either you put the vac hose on BEFORE you try to install the pipe or you do it from underneath once the pipe is on. Putting the new one on is easy compared to getting the stock one off. The stock coupler that connects to the I/C is a BIATCH to get off.
Old Apr 10, 2013 | 08:51 PM
Joe Schulte's Avatar
On the HHR pulling the radiator brackets (10mm) up off top and lifting it out the bottom helped out tremendously.
Possibly on the Cobalt as well?
Old Apr 10, 2013 | 08:59 PM
ShawnW117's Avatar
I installed mine while I was switching my intake manifold. It was easy that way but the IM is a pain to get on and off haha.
Old Apr 10, 2013 | 09:09 PM
dcrep06's Avatar
X2 i had to be so careful not to scratch the nice beautiful powder coat job on the IM when reinstalling it haha. but yea, the lowering CP is a bit of a biotch. do it from under the car though IMO.
Old Apr 10, 2013 | 11:08 PM
Omiotek's Avatar
its really not that bad...... you guys are complaining over the 2.5" pipes..... imagine doing it with 3" and 2.75" piping.... no where near as easy.
Old Apr 10, 2013 | 11:11 PM
rivaladore's Avatar
Open ended flex head racheting wrenches make tight spots a breeze
Old Apr 11, 2013 | 12:24 AM
FasterIsBetter's Avatar
Its cause its the Hahn. They're a bitch. My Hahn was a pita.
Also my zzp lower pipe made it a whole lot easier.
Last edited by FasterIsBetter; Apr 11, 2013 at 12:24 AM. Reason: Automerged Doublepost
Old Apr 11, 2013 | 01:20 AM
Omiotek's Avatar
the pipes are all pretty much the same. are they the easiest pipe to install in the world? no....go try working on a 3000gt or stealth with twin turbos....then you can complain about piping.
Old Apr 11, 2013 | 01:25 AM
No they're not. The Hahn has the most direct route to the throttle body from the inter cooler which makes it the tightest and hardest fit out of any other pipe because all others follow the same route as the stock lower piping. And if you want hard try an Audi s4. Much harder than a stealth or 3000gt.
Old Apr 11, 2013 | 06:44 AM
dcrep06's Avatar
thats the love/hate thing with the hahn lol. nice and direct, but just so much tighter in space.
Old Apr 11, 2013 | 08:32 AM
Omiotek's Avatar
been their done that...... or the piping or exhaust on the twin turbo bmws. theres a lot of cars out their that are a royal nightmare to do.
the hahn really isnt that bad and nore are the rest. the hardest one ive had to get in is my 3" reverse flow piping for the cobalt. probablly just sucks for you guys doing it on your back.
Old Apr 11, 2013 | 08:38 AM
C_A_D88's Avatar
Treadstone one was a pain
Mind u I did mine without a jack.
Just slammed the rear and aired up the front lol
Old Apr 11, 2013 | 08:58 AM
dcrep06's Avatar
big hands get in the way. i had a pain getting the sensor and hose back on -________-
Old Apr 11, 2013 | 09:02 AM
user 72239's Avatar
**** i've done the lower charge pipe so many times its easy now. the stock one is the bitch to get off.
I had to put the vacuum line on before I put the charge pipe in. Makes it much easier
Old Apr 11, 2013 | 09:13 AM
hucks1987's Avatar
i just pull the intake maifold off, and if you remove the main fuel line where it connects to the HPFP it is 100% easier. i just had to put on the new zzp lower, and thats how i did it. took me less then 30 mins
Old Apr 11, 2013 | 09:52 AM
Nah, my ZZP lower charge pipe is cake. Its just that ***** Hahn made that I ever had issue with.
Old Apr 11, 2013 | 10:37 AM
Sox-Fan's Avatar
Got Brakes?
Try TurboXS with 3 bar sensors and a TR8 beta kit. Twice the piping, double the fun. (and chances for a boost leak)
Ugh.
Old Apr 11, 2013 | 10:46 AM
user 72239's Avatar
Ugh.
haha. Injen upper pipe + TR10 + stock lower pipe right now for me!
Old Apr 11, 2013 | 10:53 AM
Sox-Fan's Avatar
Got Brakes?
The TR8 comes with the extra elbows between the IC and the charge pipes. Does the 10 have that setup too? 4 clamps and 2 couplers at each end of the IC was something I wasn't a fan of, but on the other hand, it sure gave more flexibility for mounting and location, which I really really was a fan of.
Old Apr 11, 2013 | 10:55 AM
user 72239's Avatar
Yep. exact same setup. Getting the elbow in the stock lower CP was a HUGE pain in the ass.
Old Apr 11, 2013 | 12:48 PM
colodude18's Avatar
Wanna help me replace mine some time?
I have the stock installed now because the Hahn ate my AC harness...
I put that Hahn on 3 or 4 times and it has not gotten ANY easier lol
Old Apr 11, 2013 | 03:03 PM
m33pm33p's Avatar
i threw wrenches at my truck trying to get the lower charge pipe on in anger, then when I did get it on I did a tuned pull on the highway and popped it off and went into limp mode LOL. Urge to kill rising.
Old Apr 11, 2013 | 03:05 PM
user 72239's Avatar
if you need help, I'm down
