I keep getting P013A and E codes.
I keep getting these codes. Within a 20 minute drive it can come on, go off, and come back on. It just comes on when it wants to. Mods are MPX catless dp, trifecta tune, and k and n sri. The car seems to run a bit rich at wot which could be normal with the tune. I've noticed on a NLS from 2nd to 3rd with the tune on the pop is followed by a black puff thats visible from the drivers seat through the mirror. What could be causing the codes?
The ECM detects that the time for the sensor voltage to transition from 0.4 to 0.2 volt exceeds 0.4 second. It basically missed the timeout window when you pushed in the gas pedal and the computer wanted a certain input from the O2 sensor and didn't get it. It could also mean you have a blown head gasket or a cracked ceramic in your O2 sensor, if that makes you feel better.
I also keep getting this code, well my Aeroforce Gauge says P0131, but Firestone says it's P013A, so I'm getting a new sensor put on.
Hopefully this fixes the problem on my ZZP Spun Metal Cat.
*Edit*
NM, they wanted $360 for it so I told them no!
*Edit*
