Pwerks intake looks like a pretty slick setup also. Congrats guys. Someday I will be doing this also.
(Post 7646684)
That's alot of gauges lol looks good tho
I'm a gauge whore lol
Originally Posted by Snail_SS
(Post 7646698)
Well I mean you do have alot of things to monitor like KR,AIT2,boost,maybe rpm for shift light with the interceptor, air fuel ratio, coolant, STFT and LTFT. I'm sure he's measuring some other stuff but that's just a few
(Post 7646732)
I know of parameters you can monitor I just wondered what all he was monitoring. You could cover a lot of those with a single tablet or smart phone and a bluetooth OBDII adapter. I personally monitor AFR, IAT2, boost, and keep the coolant temp up on the dash. I would like to do a gauge for oil pressure and maybe even oil temp. But even after that Tom would have 3 more gauges lol so I was just wondering what all he was monitoring out of curiosity. |
I almost sure he's monitoring every I've mentioned plus the aeroforce do 2 monitors at a time, so just in those he can see 6 things lol so technically he has 11 gauges lol
(Post 7646737)
He molded it in actually he has pics somewhere in the thread
I monitor oil temp and pressure, fuel rail pressure, stft ltft, knock, afr, meth failsafe, boost, coolant temp, exhaust gas temp and the volts is just cause I had an open pod. And yes I built the dash , thats my third attempt, first 2 sucked lol
Lol well looks good now haha
Ya I'm pretty proud of it lol
Don't forget EGT sensor very important a lot of guys miss that but if your going to be wot for 3-4-5 gears temps get up quick
1 Attachment(s)
Pwerks-performance Autowerks
Originally Posted by zeeky420
(Post 7646794)
Sry missed it tomj
(Post 7646806)
Sry missed it tomj
Almost got it all done. Waiting for new oil line junk, a fitting and some stuff from Powell. Filled with oil and coolant , will finish coolant when I can start get. Almost done bleed brakes but one of the rear bleeder screws didn't wanna come out so had to order new one since I destroyed it, gonna be a little work getting old one out
https://cimg0.ibsrv.net/gimg/www.cob...3751f9bc00.jpg Shes almost done. https://cimg2.ibsrv.net/gimg/www.cob...f1cc2b99f1.jpg Looks so good. |
Does anyone else have a real hard time plugging the rad fans in? I push the connectors as hard as I can and it will not click in. Although I looked at the fan and it seems where the connector should clip in looks broken. But ya every time I have to do this it takes forever to get them in. At this point it's in real right but not locked so I'm guessing over time I'm gonna have to go under and do it again. That or buy new fans . pisses me off a little
Blow them out and use some sort of lube on the rubber seal.
It's amazing how much it helps. |
(Post 7646906)
What kind of head unit is that?
Originally Posted by heeter_33
(Post 7646919)
