I'm thinking I should start a build thread. Guess this is it.
Old 11-02-2016, 11:44 AM
  #76
LNFwagonSS's Avatar
Hey Tom, great build BTW. Very well and tastefully done sir. You gonna go with a 445 trans for this or have you decided? Not sure what your running now.
Old 11-02-2016, 01:27 PM
  #77
tomj77's Avatar
I got 4.05 , 445 is to hard to get. The s257 wont be as hard on the trans as the zfr.
Old 11-02-2016, 01:30 PM
  #78
tomj77's Avatar
Thanks btw. As i go i think of new ways to clean it up so i do em lol it cost a bit after awhile but it looks good
Old 11-02-2016, 02:11 PM
  #79
LNFwagonSS's Avatar
I'll have my 4.45 up for sale soon if your interested. The 445 will compliment your setup quite well in terms of power delivery. Regardless, i would like to see how well the 4.05 works for you with that setup before changing anything.
Old 11-02-2016, 03:40 PM
  #80
tomj77's Avatar
Ya i dont got the cash for anothet trans lol not at this point anyway
Old 11-20-2016, 09:07 PM
  #81
tomj77's Avatar
Finished making my oil drain, if anyone is running a a big turbo and wanting a an10 braided. Stainless line with an ends, on the s257 and probably 256 and 259 the line needs 1 45 degree end one straight and has to be exactly 10.5 inch from end to end. Can get the an10 drain fitting from treadstone
Old 11-20-2016, 09:10 PM
  #82
tomj77's Avatar
I did originally have a braided nylon line but it didnt work out, i used the reusable end from that line to make myself a custom braided stainless line which worked well once i clocked the center section so it was pointed straight down, i had it angled back a bit before which made it impossible to use stainless, but all fixed now
Old 11-20-2016, 09:49 PM
  #83
63 Nova SS's Avatar
Good thinking
Old 11-20-2016, 11:05 PM
  #84
Omiotek's Avatar
Finished making my oil drain, if anyone is running a a big turbo and wanting a an10 braided. Stainless line with an ends, on the s257 and maybe 256 and 259 on zzp manifold. the line needs 1 45 degree end one straight and has to be exactly 10.5 inch from end to end. Can get the an10 drain fitting from treadstone
they would have to run your setup exactly. The reality of it is that different exhaust housings can vary and place the center cartridge in different spots. The fittings are one thing but the length should be determined by the person in the car unless they run the same setup.
I have used a multitude of different lines. Even cheaper russell pushlock hose with thermal wrap. -10 is the way to go for sure for turbos of this size.
Old 11-20-2016, 11:47 PM
  #85
tomj77's Avatar
ya this is true. only for 257 on zzp manifold then I guess lol. But I still recommend making ur own stainless braided line with the reusable fittings, very easy and cheap to do. can find good prices at summit. best part about using braided stainless rather than just rubber, the stainless line pushes the oilpan side fitting down so there is no movement or risk of leaks. you have to screw it onto the fitting before u put the fitting in the drain hole.
Old 11-20-2016, 11:50 PM
  #86
tomj77's Avatar
Good thinking
ya I don't know why I had it that way lol it looked straight but it was like a few degrees off. I just kept it loose till line went on then tightened it there. ended up being straighter. guess I need glasses lol I really do.
Old 12-02-2016, 09:51 PM
  #87
tomj77's Avatar
I decided to go ahead with sound deadning. It has begun
Old 12-03-2016, 07:31 AM
  #88
63 Nova SS's Avatar
Why?
Old 12-03-2016, 08:55 AM
  #89
What did you buy?
Old 12-03-2016, 09:03 AM
  #90
Originally Posted by Snail_SS
What did you buy?
Looks like dynamat
Old 12-03-2016, 11:39 AM
  #91
tomj77's Avatar
Why?
cause I don't like cranking up my radio to drown out certain noises I don't want to hear, like gas tank sloshing, rocks hitting under the car cause I drive a lot of gravel roads. and yes, the exhaust can get annoying on long trips, I love it with the windows down and all, but sometimes, I just want it quieter on a longer trip. my reasons, don't have to like em, but that's what they are
  #92
tomj77's Avatar
yes its dynamat
Old 12-03-2016, 11:45 AM
  #93
tomj77's Avatar
amazon.ca had it for 266 for enough for entire car, and now its down to 212. some people may think its dumb, but lets face it, especially if u have to drive gravel, there are some noises u just get tired of hearing. even the exhaust hum can get annoying on long drives. so no I got the option, open the window and hear what I like, or close it and have it quieter if I want.
Old 12-03-2016, 11:54 AM
  #94
63 Nova SS's Avatar
Valid reasons, I purposely don't drive on gravel and am lucky I don't have to. My exhaust drone is pretty quiet inside the car, as I'm running a resonator and a muffler but I understand the need.
Old 12-03-2016, 12:02 PM
  #95
tomj77's Avatar
I am as well, the drone isn't to loud but after listening to it for an hour or more, it just gets annoying lol. I like it for only so long. ya gravel sucks.
Old 12-03-2016, 12:24 PM
  #96
Nice I've been wanting to do something like that
Old 12-03-2016, 12:52 PM
  #97
That's a pretty good price. Totally worth it, I need to do drop some funds into some dynamat and the foam they sell also, double layering it really makes a difference
Old 12-03-2016, 01:56 PM
  #98
tomj77's Avatar
Do it man. And it only adds like 20 lbs if u use the entire car kit. They have alot of good products and excellent reviews on all
Old 12-03-2016, 02:38 PM
  #99
How much did you buy tom?
Old 12-03-2016, 10:59 PM
  #100
tomj77's Avatar
enough for the entire car. 9 18x32 sheets look up dynamat on amazon, its the first link. $212.
Quick Reply: I'm thinking I should start a build thread. Guess this is it.
