Intakes?
Old Jun 30, 2015 | 01:05 PM
Teetzel's Avatar
Intakes?
I currently have a k&n short ram intake on my 2010 ss/tc.
Was told that once I start doing tuning and bolt ons I should get a proper cold air intake that goes into the wheel well.
Was also told by a different guy that if I want to do a bigger turbo I should have the intake that I already have.
What should I do? Switch intakes or keep the short ram?
Thanks!
Old Jun 30, 2015 | 01:07 PM
Keep it
Old Jun 30, 2015 | 01:08 PM
sc4door's Avatar
Keep it. The ones that go down into the wheel wells just increase your chance of sucking in water and causing problems
Old Jun 30, 2015 | 01:46 PM
hawkssoccer11's Avatar
keep it. i had a full cold air for a while and then i switched to the sri and ill never go back absolutely love it
Old Jun 30, 2015 | 01:53 PM
Exactly what everyone said
Old Jun 30, 2015 | 01:55 PM
Sl0wbaltSS's Avatar
Cold air intake temps, not much spooling sound, less chance of knock, possibility to suck in water when it's raining. Or, hotter air, spooling sound, bpv sound, more chance of knock. Your choice.
Old Jun 30, 2015 | 01:58 PM
umrdyldo's Avatar
On a hard run you aren't sucking in much hotter air than outside temp.
You might gain a HP or 2, but the K&N is one of the better intakes to tune.
i just did the MAF tuning on mine. Had to adjust a good bit but not bad.
Old Jun 30, 2015 | 03:36 PM
Do you have proof of an actual difference? Also where do you get the idea a K&N intake increases knock, because they dont...
Of course you don't you just follow what every ricer says....
OP keep the K&N, no need for another different intake, the temp difference between a SRI and a CAI are insignificant during a WOT pull. None of the CAI's come close to a nice ram air style they offer for most trucks that actually make a difference
Old Jun 30, 2015 | 03:55 PM
umrdyldo's Avatar
Bahaha, please don't post misinformation. It's confusing to newer people.
As said, while moving there is almost no difference in intake temp between ambient air.
Knock is mostly about tune. Intercooler will help incoming temps more than anything.
on these cars, having straight air across the MAF is the most important thing. Most cold air intakes on this car skew the MAF a lot and are not easily tuned.
Old Jun 30, 2015 | 04:02 PM
I was going to tell him something but damn. now all he needs is to tell him to do the vaccum tank delete hahahaha (op dont do the vaccum tank delete)
Old Jun 30, 2015 | 04:26 PM
umrdyldo's Avatar
I have been without the vacuum tank so long i don't even know what it would be like to have it again.
Old Jun 30, 2015 | 04:54 PM
Its the same thing to me
Old Jun 30, 2015 | 05:25 PM
The other guy who gives shitty advise was telling someone to remove it for a completely unrelated issue. I agree if the tank is cracked and leaking pull it outta there, but if its not cracked leave it alone
Old Jun 30, 2015 | 06:08 PM
umrdyldo's Avatar
Yeah I was in that thread.
I agree it was probably best to leave alone
Old Jun 30, 2015 | 06:52 PM
I always forget who else posts in most threads, I just try to keep people from reading what he says as actual good information
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Sep 25, 2015 06:06 PM
