intercooler issue
Old Mar 21, 2015 | 09:24 PM
Thomas L Edwards's Avatar
Exclamation intercooler issue
I just bought a intercooler kit from Treadstone Performance and the lower cold side pipe doesn't have a vale for the vacuum line...what can I do to compensate for the vacuum line??
Old Mar 21, 2015 | 10:09 PM
Superbolt's Avatar
Guess it's a turbo intercooler
Old Mar 21, 2015 | 10:19 PM
Yes. It's a 09 turbo ss
Old Mar 21, 2015 | 11:29 PM
tomj77's Avatar
theirs don't have it. u have 2 options. u cant just run the line that's supposed to connect to the charge pipe fitting teed into the intake manifold port, or u can weld a bung into the charge pipe and ull have one. I welded on on bung when I had that pipe. teeing into the intake manifold line will work, but it will not be able to work the way it was ment to. that line is only supposed to see boost and not vacuum, just like the one on the other end of the bpv solenoid is only supposed to see vacuum, its for the ecu to be able to open vacuum or boost to open or close the bpv for motor protection if something were to happen and it had to. u can do it the easy way, if u want it to see only boost and just put a check valve on the line and ur good.
Old Mar 22, 2015 | 01:40 AM
Damn!!! Thanks Tomj77. I think I'm going to inform Treadstone about this defect and return the lower pipe. I paid too much to be cutting and welding on pipes. Again thanks
Old Mar 22, 2015 | 08:09 AM
REDi DEViSTATOR's Avatar
Funny, cuz I'm SURE he actually posted in the LNF section. I'm not 100% sure but IIRC that's the turbo version, no? Common sense, no?
Old Mar 22, 2015 | 09:49 AM
tomj77's Avatar
its not a defect, they knew they don't have it in there.
Old Mar 22, 2015 | 03:30 PM
Okay Tomj77. Which intake manifold line am I supposed to feed it into.
Old Mar 22, 2015 | 05:14 PM
tomj77's Avatar
There is only one, that one. Lol the small vac line going into the top of the intake manifold. Only one there. If u look at it it runs down under the manifold to the vacuum canister.
Old Mar 22, 2015 | 05:22 PM
Sl0wbaltSS's Avatar
You can take off all the vac lines completely except the one that goes to the BPV and hook that one up directly to the intake manifold.
Old Mar 23, 2015 | 10:19 AM
CudaJoe's Avatar
cant you just tap a bung in? why weld?
Old Mar 23, 2015 | 11:07 AM
I dont think treadstone's plate they welded in is large enough. Otherwise youre going into ~20 gauge aluminum which isnt enough to hold a thread.
OP treadstone's is a shitty design and will fit like poo poo. If you can return it without re-stocking fees do it. Then either buy zzps or pwerks
Old Mar 23, 2015 | 12:44 PM
tomj77's Avatar
Treadstones fits a heck of a lot better than zzps, unless zzp fixed theirs. Treadstones took 10 minutes to install where as zzp took like an hour plus, and after doing that once I just cut it off and used a 90 degree coupler.
Old Mar 23, 2015 | 01:02 PM
I was meaning the whole kit, not just the lower CP. With zzp's its just a matter of orienting it correctly which takes a bit.
Old Mar 23, 2015 | 03:19 PM
tomj77's Avatar
Oh the whole kit, I'm talking just putting on the pipe with everything else already on, I'm sure doing everything together is much easier
Old Mar 23, 2015 | 03:24 PM
The fitment of the whole kit sucks, the intercooler brackets are a bitch, and the fact they continue to not use the correct vacuum connections even after many have told them its missing.
Old Mar 23, 2015 | 05:40 PM
tomj77's Avatar
Who's we talking aboot here
Old Mar 23, 2015 | 05:44 PM
Treadstone's.
Old Mar 23, 2015 | 06:16 PM
I got my zzp one on sept and i had no problems putting it in
Old Mar 24, 2015 | 12:51 AM
I NEED a diagram or something for the vacuum lines. I don't have the turbosmart BOV and need to route things so my car functions properly. Treadstone effed up the lower charge pipe and does continue to. But if anyone has a diagram showing how they actually routed their vacuum lines without the Aftermarket BOV valve I'd love to see it.
Old Mar 24, 2015 | 02:41 PM
tomj77's Avatar
a
I don't have a pic but I can write it.
tomj77's Avatar
Intercooler or lower cp
Old Mar 24, 2015 | 02:46 PM
a
Shucks I'll take that Tomj77 anything will help.
Old Mar 24, 2015 | 03:02 PM
I got everything
Old Mar 27, 2015 | 07:23 PM
Superbolt's Avatar
My bad
