Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   Issues with LNF with Vac and random KR (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/issues-lnf-vac-random-kr-319356/)
Sl0wbaltSS Sep 29, 2015 02:25 AM
So for the past week the car has been having an ANNOYING amount of KR in every gear but not at WOT. In first it's been showing 11.9 kr 2nd 8-12kr 3rd 3-9 and so on. I've also had the vac never go to 20-22 it's always been at 18-20 since the new engine was put in. Currently on full E for 2 weeks before it started happening, didn't put new seals in stock injectors, ZZP LNF fuel lobe cam is in.
My tuner suggested rotate and re torque knock sensor and I suggested to switch injectors with my brother's old injectors laying around. Rail pressure at WOT is 2300-2450 till 6600, never logged above that.
I've tried disconnecting the battery for a couple of min, clearing DTC's when there's none, disconnecting EVAP solenoid, and it did run PERFECT for 1 night for like 2 hours until the next morning then it started running like crap again. That was with only disconnecting the battery.
On the aeroforce gauge I have it shows a max KPA of 255 at wot which is weird, it also shows 22.7 PSI at wot but my factory boost gauge says 25 PSI.
If you need logs I can get with my tuner and get some. In the mean time I will swap injectors and rotate those knock sensors.
kzak104 Sep 29, 2015 09:26 PM
the interceptors pin at 22.7psi for some reason, dont read boost off them, and did you get a bad batch of gas possibly
ECaulk Sep 29, 2015 10:23 PM
What are your fuel trims? Difference in commanded lambda and actual lambda? What timing advance is it calling for in the tune file vs observed? And what is your injector ms?
Sl0wbaltSS Sep 29, 2015 10:39 PM
I would have to log that stuff. Fuel trims are within 2% positive for LTFT.
ECaulk Sep 29, 2015 11:15 PM
Stft matters a little more for KR
ECaulk Sep 29, 2015 11:16 PM
I also hope your tuner is logging those parameters or you're close to a new engine
nathan112i Sep 29, 2015 11:18 PM
good, now do a log and look at this things ecaulk told you to look at but this time look at stft
Sl0wbaltSS Sep 30, 2015 01:44 AM
I'll look at my stft and KR at the same time on my aeroforce. Can't log to prob friday.
Psykostevo Sep 30, 2015 12:39 PM
We will take a look at another log if you guys want. We scanned it again on Saturday, and his knock sensors are definitely logging feedback, but the car I am not detecting any real knock. I suggested the rotation and re-torquing of the knock sensors due to that helping some people with false knock issues. The most notable issue is that his car (exhaust, etc) rattles badly, so he has some contact somewhere that could now be passing along the vibration to these sensors. He is getting high amounts of feedback on both knock sensors at the moment.
When we initially spent 2 sessions tuning the car there was no knock what so ever, not even the feedback that he is now getting. On Saturday when we looked back over the car, he would have pretty much anywhere from 8-11.9 degrees of KR just cruising and then it would go away at WOT. I am very inclined to think that the metal on metal contact is less severe during WOT. I am nearly convinced that the rattling of metal on metal contact on his car is causing the reading.
There are some other suggestions I made for him as far as upgrading his injectors, so that we would not be so limited on fuel delivery, but that wouldn't be a cause for knock unless somehow his injector seals disappeared on his current injectors. We aren't hearing any popcorn noises that typically are described when injector seals fail, so he's probably alrught for now in that department.
Psykostevo Sep 30, 2015 12:42 PM
From logs during 2nd tuning session.
Injector MS
https://www.cobaltss.net/gallery/fil...njector_ms.jpg
STFT
https://www.cobaltss.net/gallery/fil...burgosstft.jpg
Knock Retard
https://www.cobaltss.net/gallery/fil...urgosknock.jpg
ECaulk Sep 30, 2015 12:46 PM
I'm assuming those are the averages?
We really need to see whats going on at the point the knock is registering, not averaged values after the fact.
Psykostevo Sep 30, 2015 12:57 PM
I will have to pull you logs of his current situation. Right now when it's in gear it just registers knock sensor data in basically every idle or cruising cell, average values and all.
Jacob, any luck on getting your pipes to stop rattling on the car?
Sl0wbaltSS Sep 30, 2015 10:27 PM
Haven't gotten to it, had a graveyard shift and worked 10 hours. Tired and don't really wanna use a crappy tool to losen them and put them back in lol. Will work on tomorrow though.
Sl0wbaltSS Oct 3, 2015 10:47 AM
Bumpity bump bump.
Sl0wbaltSS Feb 5, 2016 01:01 AM
firehawk618 Feb 5, 2016 11:11 PM
Your tuner says your exhaust rattles like crazy.
You can't sit there and try to troubleshoot KR when you have crap rattling all over your drive train causing potential fake KR.
My car will go crazy with what I determined to be false KR. I have never seen it actually pull any timing in my logs when it registers KR.
I will get it off idle when i'm just lightly accelerating and it will go away completely if I get on it.
Recently I noticed at a certain RPM when the car is warming up I can hear something under the car vibrating *heat shield I presume* and am also going to assume that very well be the trigger of my false KR I register.
You said your exhaust is rattling like crazy. That's the #1 thing to fix.
You can't do much until you fix it.
Dutchman Nov 17, 2016 12:00 PM
uh sorry for the thread revival but when did the former scion guy get banned?
his advice use to be good for a laugh at least lol
Staged07SS Nov 17, 2016 12:59 PM
I banned him Monday after complaints. He is not perma banned yet, and will be back in a month. Hopefully he grows up some in that time.
Snail_SS Nov 21, 2018 11:11 PM
Bump because I will need this info
