Limp Mode Check Engine Light
Old Apr 8, 2009 | 11:48 PM
09Black SS/TC socal's Avatar
I was driving home from class tonight on the freeway and zoned out so much that at 85 mph i shifted from 4th to 3rd instead of 5th gear and my car red lined and went into limp mode.
I threw on the flashers and pulled over, turned off my car,turned it back on and it started running again.The only problem is now the check engine light is staying on.
I'm hoping it's just because the car may have overheated or freaked out and needs some time to chill out but I'm wondering what else it could be and what I should do?
Old Apr 8, 2009 | 11:49 PM
CobaltVenomSS's Avatar
that redlined it in 3rd??? gearing must be way different then ss/sc
Old Apr 8, 2009 | 11:58 PM
Scott2008SS's Avatar
Our third usually gets to about 100MPH
Old Apr 9, 2009 | 12:05 AM
MoePwR's Avatar
mine did the same thing last night sorta.... try clearing the code/ disconecting battery for <10
Old Apr 9, 2009 | 12:56 AM
tomj77's Avatar
100mph, ud hit rev limiter in third at 100mph, the best iv done is about 90mph in 3rd
Old Apr 9, 2009 | 12:59 AM
1badBlueberrySC's Avatar
I get to about 105-107 in 3rd gear!
cobaltssoverbooster's Avatar
red line raised to 7300 and u get 102 mph 8D i did that but turbo drops looses its ***** after the factory redline.
Old Apr 9, 2009 | 01:01 AM
Not everytime... Mine pulled pretty well all the way to 6800
Old Apr 9, 2009 | 01:09 AM
yea mine varies on temps outside too the other day it was like 60 and dry and it was haulin ***** everywhere.
Old Apr 9, 2009 | 01:13 AM
HA HA HA....
Check your PM's on LNF
Old Apr 9, 2009 | 02:55 AM
fshizl's Avatar
i took mine into the dealer last time that happened, he told me engine misfired. it happens with no lift shift too if you mess up.
Old Apr 9, 2009 | 12:50 PM
I shifted into third and pressed the gas to speed up .
As if I was downshifting into 3rd and not knowing it so i pretty much pushed it to the rev limiter.
Old Apr 9, 2009 | 12:54 PM
steddy2112's Avatar
3rd goes to 105
and it takes a few seconds FLOORED to get there.
What is the code?
Your story stinks
Old Apr 9, 2009 | 04:29 PM
tlake84's Avatar
You also get misfires quite often if you get on it if the engine is still <170 degrees... Just an FYI.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
