Limp Mode With Dejon Intake?
I installed my Dejon Intake over the weekend and it threw 2 codes and the CEL.
The 2 codes are...
P101 - MAF or VAF A CKT Range
P2178 - System to Rich off Idle speed (Bank 1)
My car goes into Limp mode for no reason for about 5-10 min. My tuner, Dejon, and myself think that the line from the Valve cover to intake needs to be replaced. (Braided Line)
Opinions and Ideas please.
The 2 codes are...
I insalled mine and only took about 10min I also have my breather valve vented into the atmosphere. Try this Disconect your battery and take your maf out and turn it around and re install it. It sounds like you put it in backwards. Let me know how this works out for you.
The 2 codes are...
The 2 codes are...
The 2 codes are...
The 2 codes are...
Last edited by Terminator2; Jul 6, 2009 at 01:35 PM. Reason: Automerged Doublepost
When I had the Dejon intake on, I wrapped the breather connection with self fusing rubber tape to seal it. Scotch 130C works well & is hi temp. The fitting on the Dejon is marginal at best.
I dont understand whats going on....Ive had my Dejon on for like 3 or 4 months and have had no CEL or any other problems. Im considering going back to stock because of all these problems, but I dont know if I should seeing Im not having any.
I never threw a code with the Dejon intake, but since I am tuned for the stock airbox, it didn't run as well. From what I've seen posted by others, I'm pretty sure it was running rich. (no way for me to read the F/A ratio) If you have the means to scan yours, check it out.
When i put on my Charge Pipes i let my car idle for about 3 minutes, then took it for a quick pull and i threw the limp mode code. disconnected the battery for 10-15 mins and started it up again and it was fine
I'm the tuner. the cars stft's are -10-(-20%). which indicates that the sri is bleeding are off after the maf. when I put my dejon sri my stft's were in the +2-(+5%) range in some areas and i did very little maf table changes.
2FST4U I told you to take the intake off and reinstall. I would run a hose from the nipple on the intake to the valve cover. you need to put a one way check valve in this hose because if you dont it will allow oil to get into your intake track and a wet intake = less cfm and drivability concerns. if you dont want to do that then you can plug the nipple on the intake with a vaccum plug and put a filter on the nipple coming off the valve cover but be I have seen these filter fill up with oil and start blowing it all over the back of the valve cover.
I just ordered the H/P check valve and filter so I should have it by friday. I will call you and let you know. BTW vern I killed an LS1 camaro SS 2 days ago. He was impressed
