LNF boost issues
Old Apr 8, 2016 | 12:02 AM
Tstanley91's Avatar
LNF boost issues
My 2010 cobalt ss is having a lot of problems with boost. My boost is getting up to maybe 5 psi on good day. I've checked all the vacuum lines and then inter cooler hoses and everything and couldn't find a leak. My blow off valve is also not releasing all at once makes a tututu then a psh. Someone please help.
Old Apr 8, 2016 | 06:40 AM
Dutchman's Avatar
Have you scanned the car? Gotta find out if you're throwing codes, then you can start to figure out the problem
Old Apr 8, 2016 | 08:24 PM
tomj77's Avatar
How did u check for leaks? Did u look or actually do a boost leak test with a boost leak tester? U throwing any map sensor codes? Did u get the 3 bar sensors and have the new plugs soldered in or u have the pig tails? For ur bpv unplug it from solenoid and plug into intake manifold straight. See if it fixes. Let's start with those questions.
Old Apr 12, 2016 | 01:26 PM
Tstanley91's Avatar
I had it checked for boost leaks and I have the 3 bar map sensors and its spliced in. And my bpv is already tied directly to my intake. It randomly started working right again so I'm gonna go through and solder my map sensors in instead of them being spliced for a better connection and see if that helps
Sharkey
Apr 15, 2016 09:13 PM
yellow_cobalt
Apr 3, 2016 09:20 AM
slowbaltstp
Apr 3, 2016 03:59 AM
austin8898
Apr 2, 2016 01:03 PM
