Lnf p0449
Old May 31, 2017 | 11:46 AM
royce777's Avatar
Lnf p0449
So my sedan sat for two days then I got in it and started it yesterday morning and had a CEL. I am getting a P0449. I filled up gas on Sunday morning before I parked it. I checked the EVAP purged valve on the intake manifold and it is good. It only has 10k miles but I still checked it. I also checked the wiring under the rear of the car and it is fine.
So before I just start replacing things I am wondering. I know it can be a few different things such as:
-gas cap
-canister vent valve solenoid
-vapor canister
If I clear the CEL it comes back right after I turn the car off then on. This makes me think it is something electronic. I pulled the vent valve solenoid on the vapor canister and it appeared to be fine. Also over the past few months I noticed my MPG has been only 27MPG and I usually get 30MPG (both mixed of around town and highway). I know the gas cap and vent valve solenoid are relatively cheap but I would like to see if anyone else has had this problem.
Old May 31, 2017 | 02:40 PM
Tdubbs's Avatar
I haven't had the issue on the Balt, but over the years as a mechanic I've seen GM vent solenoids fail left and right. Did you just inspect it, or did you try to actuate it with power?
If you didn't, take it off and use some jumper wires and tap it to the battery and see if it gives a satisfying thunk.
Edit: Forgot to add, if you have access to a scan tool(Snap-on, OTC, etc.) you can actuate it via the pcm and see if you have a good power and ground at the connector.
Old May 31, 2017 | 03:17 PM
royce777's Avatar
I inspected it and push the center of it to make sure it wasn't seized. The spring loaded part of it moved freely. I unfortunately don't easily have access to a scan tool. I will try to use jumper wires and see if it will make the thunk.
Old Feb 15, 2018 | 09:09 AM
Prestige_Worldwide's Avatar
Did you figure out what the culprit was? My HHR SS just popped the same code after sitting like you said, I cleared the code and it came back after a short ride.
Old Feb 15, 2018 | 09:14 AM
royce777's Avatar
vapor canister on the intake manifold. $15 part
Old Feb 15, 2018 | 09:31 AM
10-4, thanks for the update!
Old Feb 15, 2018 | 11:39 AM
umrdyldo's Avatar
For those that see this thread. The part is called the evap purge selenoid.
It's a very common failure on these car. I went through one every 18 months.
Old Feb 15, 2018 | 01:01 PM
royce777's Avatar
GM part # 12592015
Old Feb 15, 2018 | 03:35 PM
exninja's Avatar
Still on original (knock on wood)
Old Feb 15, 2018 | 04:18 PM
royce777's Avatar
your LDK didn't come with a new intake mani and accessories?
Old Feb 15, 2018 | 04:34 PM
exninja's Avatar
Negative. Reused the LNF manifolds.
Old Feb 15, 2018 | 04:36 PM
royce777's Avatar
did you atleast get a new turbo with yours?
Old Feb 15, 2018 | 04:42 PM
exninja's Avatar
Lol no on that too.
Old Feb 15, 2018 | 06:49 PM
Are the aftermarket brands from autozone decent? None of the part stores around me have the AC Delco part. If not I’ll order one online.
Old Feb 15, 2018 | 07:54 PM
royce777's Avatar
get acdelco
Old Feb 15, 2018 | 08:23 PM
63 Nova SS's Avatar
Still rocking my stock one also but I only have 42k miles on the car.
Old Feb 28, 2018 | 11:37 AM
So I had a buddy with a scanner run the code and it was the vent solenoid, the purge was clicking and functioning as it should when we tested it. So I replaced the vent solenoid this past weekend and have driven over 3 full drive cycles and it's not going away. Could it be something else other than the vent solenoid?
Old Feb 28, 2018 | 11:53 AM
The code points towards the control circuit itself.
Old Feb 28, 2018 | 01:05 PM
How do you go about fixing that then?
Old Feb 28, 2018 | 02:18 PM
umrdyldo's Avatar
GM part # 12592015
Old Feb 28, 2018 | 02:25 PM
Test for power, ground, continuity check wires...
multimeter is your friend
