LNF PCV Anti-coking drain back system
Old Jul 10, 2014 | 12:31 AM
  #301
SINISTER's Avatar
Originally Posted by ECaulk
Post a photo of yours. That is a stock mani in that pic
I was wrong...see my post above yours. Car is new to me didn't realize it was flipped..
Back on topic...Im an idiot...
Old Jul 10, 2014 | 06:31 AM
  #302
no worries, had I not ordered a spare for when I clean my valves (checked with a bore scope and my IM is dirty pretty sure I have a failed PCV valve) I probably would of though similar. Just a side note for those cleaning valves, check your IM, the one I bough used had some oil build up/coking on it not significant but there was still some build up.
Old Aug 30, 2014 | 04:03 AM
  #303
Waka Flocka Fluff's Avatar
My car is currently burning oil, blue smoke. I had a catchcan installed prior and relized how useless it was when my charge pipes still had oil in them. I did a compression test and it came up good. So I thought my turbo seals were shot. Do you guys recommend me trying the powell separator first to see if the problem persists? Who knows my seals my be good and I might just be getting a **** load of blow-by!
Old Aug 30, 2014 | 06:43 AM
  #304
umrdyldo's Avatar
If you are seeing a lot of blue smoke then its likely the seals.
If you had a lot of blue smoke and it was from blow by, your engine would be hurting bad
Old Aug 30, 2014 | 07:04 AM
  #305
Originally Posted by umrdyldo
If you are seeing a lot of blue smoke then its likely the seals. If you had a lot of blue smoke and it was from blow by, your engine would be hurting bad
it's gotten worse now that it is hot out. The plugs need to get replaced it again, however I seafoam it every oil change and it doesn't smoke much at all... Should I try this first as an alternative and if it persists go on with replacing the turbo?
Old Aug 30, 2014 | 09:59 AM
  #306
Clean your charge pipes and intercooler if the smoke is reduced after that then Powell's solution will help. If no change then you have other issues to address first.
Old Aug 30, 2014 | 02:28 PM
  #307
I'm going to clean the charge pipe, silicone hoses, and install the pcv system. Then if the problem reoccurs it's turbo swap time!
Old Mar 12, 2015 | 05:14 PM
  #308
Pasierbek's Avatar
How much is the oil seperator kit now? I plan on ordering one soon.
Old Mar 12, 2015 | 05:55 PM
  #309
YelCal7's Avatar
$450 shipped
Old Jan 2, 2017 | 04:13 AM
  #310
XStylus's Avatar
Giving some thought to one of these for preventative maintenance reasons. One thing I'm curious about though:
The oil that this system catches -- where does it go? Does it flow into a catch can that needs to be emptied periodically, or does it have a way of flowing back into the engine, and if the latter, through what orifice?
Old Jan 2, 2017 | 06:59 AM
  #311
tomj77's Avatar
Look at the pic on firet page. Comes with a new dipstick tube and Jose hose connected to that and the separator so oil goes back into the oil pan. U don't need to do anything anything, it does it all for you. V3 is way to go, it addresses the pcv valve port as well
Old Jan 2, 2017 | 07:27 AM
  #312
cw383's Avatar
Is there a link anywhere to the difference of the V3 vs prior designs? I got mine in 2013 I beleive, so I'm sure it must make it a V1 or V2
Old Jan 2, 2017 | 10:47 AM
  #313
tomj77's Avatar
Well v3 has a 3rd line to the intake manifold, if u don't have that it's v2. U can upgrade to v3 for cheaper than buying new, just email Powell
Old Jan 2, 2017 | 02:19 PM
  #314
Dutchman's Avatar
Looks like I'm taking a drive to see John again
Old Jan 3, 2017 | 05:20 AM
  #315
XStylus's Avatar
The oil goes back in through the dipstick tube? Does this mean I lose my dipstick?
Old Jan 3, 2017 | 06:13 AM
  #316
63 Nova SS's Avatar
Yes, John includes a new dipstick with an adapter tube welded to it in the kit.
Old Jan 3, 2017 | 07:34 AM
  #317
cw383's Avatar
Does anyone have a pic of the V3, or of the modification to intake manifold? I'm going to be upgrading mine, just wanted to see how the setup is
Old Jan 3, 2017 | 07:45 AM
  #318
tomj77's Avatar
No lol you get a new modified dipstick tube with an adaptor like 63 nova said, the drain hose screws into the adaptor via an4 fitting . look at pic on first post and u will see
Old Jan 3, 2017 | 07:46 AM
  #319
tomj77's Avatar
Never mind it doesbt show on there. I'll take pics later if I remember
Old Jan 4, 2017 | 03:47 AM
  #320
XStylus's Avatar
Yeah. I didn't see any indication of where the dipstick would go so I figured I'd play the part of the idiot and ask a stupid question.
And now for my next stupid question, would my car with this installed have any chance of passing California smog visual inspection?
Old Jan 4, 2017 | 05:38 AM
  #321
63 Nova SS's Avatar
The engine oil system is still a sealed unit. I wouldn't think it would change anything with smog emissions.
Old Jan 4, 2017 | 07:45 AM
  #322
tomj77's Avatar
It won't make any difference to smog tests. Actually maybe it will, no oil in intake makes for less harmful emissions so it will help you out actually
Old Jan 4, 2017 | 10:43 AM
  #323
exninja's Avatar
This^. You'd have an issue with a breather filter, but the PVC is still sealed with Powell's system. Since nothing vents to atmosphere you're fine.
Old Jan 4, 2017 | 12:57 PM
  #324
XStylus's Avatar
Right, I'm sure in terms of emissions it's just fine.
But in Cali, if I understand correctly, pretty much anything that modifies anything that in any way pertains to emissions and doesn't have a CARB approval sticker will flunk visual (the pop-the-hood-and-look-for-mods test), even if all the smog scanners say everything's perfect.
Kinda hoping there's some Cali people on this thread who could say "No, your understanding is incorrect because [insert long winded explanation here]."
Old Jan 4, 2017 | 01:08 PM
  #325
I really doubt a visual inspector will notice. But I'd wait for a Cali user to comment. You could always just disconnect the system for the visual inspection (is it an annual inspection or less frequent?)
