Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   LNF Running Temp ? (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/lnf-running-temp-278956/)
mongorat427 05-19-2012 08:49 AM
My LNF runs 180 to 195
QuickSilver_SS 05-19-2012 09:31 AM
Does your car possible run cooler due to your tune ? Or any of your mods ? I had always read that the tc's run rich. And that cars that run rich have a tendency to run a little cooler. Is that right at all ? Cause if so then you would think I tuned lnf would run hotter then a stock lnf ? Does that make sense ?
vahdyx 05-22-2012 06:36 PM
Question about oil temps, I've gotten mine to 215, is that okay? I've seen the 205 coolant, but what about oil?
peachpuff 05-22-2012 06:40 PM
With hotter outside temps the oil temp will always be a bit hotter than your coolant, also the oil temp readout is simply a formula since the engine doesn't have an actual oil temp sensor.
vahdyx 05-22-2012 06:53 PM
Okay cool, we had a record high today of 90*F and we usually don't see that kind of heat until late August and this is my first summer I believe with my Dual Aeroforce Gauges.
Didn't know, but now I do, thanks
09BlueBaltSS 05-23-2012 12:59 AM
183-189
