lnf spark plug install
Installing oem replaacement plugs balt sstc. Other than a. Cooled engine block any other tips or advice for installation?? Someone said something concerning if plugs have a gasket seat or taper seat.... It will affect the amount of rachet turn after finger tightened. Thank you
Also, could you post some pics of THOSE here when you get em out?
As far as tightening...15 lbs..that's about 1/8 turn after you first made *hand tight* with the wrench.
Lol, that was me...twice. Except, I did use a spark plug socket the second time and it happened again so...yeah. Changed a million plugs and have never seen anything like it. I've changed the plugs since then and it didn't happen again. Just very weird...
These are AC Delco. It does have a stamp on the neck says Japan and this #ILTR5D (which is NGK I assume).
No reference to NGK or 5476. I assume they're the same though.
NGKwholesale.com :: NGK :: NGK Spark Plugs :: ILTR5D
