LNF stock pistons?
Sleeves and rods? Seems unnecessary unless the owner is going to put on a ridiculously large turbo. The more it deviates from stock, the more of a pain in the ass it becomes.
Edit: Welp, I take that back. I just saw the other thread. There's one pic in there that shows a really deep "S" shaped gouge. That's probably more than one size up will fix.
Also, if there really was valve to piston contact, I would take zero chances. Change the valves while it's apart. I once had a valve stem snap at idle for no apparent reason on a race motor. All we could figure is fatigue (90k, with many of them on a race track). Not worth risking a brand new motor on something as cheap as a stock valve. No need to upgrade them. The stock ones are great (sodium filled exhaust valve stems).
and to the second point....theres a reason companies like ferrea and supertech are around. the stock components arent the worse but when you get into some serious boost an upgraded valvetrain is always needed. hell if i someone used stock valves on my camaro and i found out it would be the builders ass when the motor blows up.
Wrong! Though they are nice, sodium filled valves, they are rather small, and these heads benefit greatly from a 5 angle, 1mm larger, valve job. Also, the owner of this motor is putting on a bigger turbo... so just think, he'll be doing this to a trans in no time too. Unfortunately for him, there are no billet gearsets out... yet
Sorry, but i don't know if I'm going to take your word for it.
Not to mention, Inconel is much better than sodium filled steel valves.
K thx bai.
Brand new 3 years ago. Close, but not quite brand new. Believe it or not, there have been people building these motors since before they were even released (GASP! GMPP).
Umm, because I know of a couple builds the shop I work for, and a few other LNF builers (GMPP being one of them) that have 5 angle, 1mm larger valve jobs. The heads are our biggest restriction. A port and polish only goes so far, when you are looking to make over about 400whp, you have to do everything to make the head flow more, and it really relieves the stress on the head, and relieves the restriction of our head.
No, I don't have the actual dyno proof, but yes, I have seen it before, and the prrof is in the pudding brotha!
K thx bai.
the shop where i work on my car is almost finished up with their lnf head project. this is where mkriebs is talking about aswell. from what ive seen so far it proves your point wrong. when they get on the board as a vendor you'll see the results.
The way I look at it, if we can pick up 30whp on a decent hand port and polish, the next trouble spot we will have is the valves. Anytime you add volume, you will gain power. Sure, we might not see big gains on the stock turbo, with the larger valves, but we aren't talking anemic little K04's in this thread, we're talking about the big boys now. Anything over stock will benefit from the improved airflow.
No offense matt because i like you, but i'm not taking the word from a single shop out of the blue that has yet to actually produce a long term daily driven LNF, and can prove side by side with evidence that what they're doing is the end all be all.
As far as i'm concerned there are only about 2 people that can say with certainty what makes an LSJ tick, and they're still learning.
Volume does not always equal power. If i am proven wrong so be it, i just don't like when someone says, this single upgrade is the golden ticket.
and 3 years is incredibly new.
idk which matt that was directed twords lol. but if he then no worries man. understand your attesting a point and thats all good. thats how things improve and get better by everyone testing eachothers knowledge. ill have the proof soon enough. im saving up some extra cash to do the head. its not cheap otherwise your proof would be layed out in front of you. they have been in the lnf scene for quite a bit just not on the cobalt hhr platform. mostly solstice and sky. cobalt parts are in the works on my car so you'll see shortly when they become a vendor.
That said, GMPP was the first to build the LNF to substantial power levels, and has the most R&D in the motor, thus I will use them as a main example. They have proven the head jobs make a difference. If you want, look up a guy on the Solstice forums, and ask him. He is using a GMPP build motor in his Solstice. Its still for a rather 'mild' build, and I am not sure of the specs on it. I say 'mild' build, in comparison to what his turbo choice is, and what Cardelino's turbo choice is.
I am not entirely certain how you think more volume doesn't make more power. I somewhat can see the point in a poor port/polish job that disrupts laminar airflow. And I understand that you want to keep the flow of the head efficient, while maintaining good velocity. BUT, you also have to understand we aren't talking about your stock turbo, or TVS blown motors here. We are talking about turbos that push 70-80lbs/min, and support 700-800hp to the ground. We need to make these cars eat as much air as possible. The velocity will be there, and the air will be there, guaranteed.
I would not be so bold to make a statement that a +1mm valve job would make a difference on a stock turbo car. The stock turbo wouldn't have the breath to push the air with enough velocity, and it would be a hindrance to performance.
Yeah, there isn't a whole lot of proof that the valve jobs make a substantial difference, but the proof is there. The biggest proof I have is GMPP. Plus, beyond that are the numbers I have seen from not only plain old port/polish jobs, but also minor, and major valve jobs. And then, lastly, the logic behind it all. Obviously as airflow increases, the need for more volume increases.
Its just like the analogy of boost, using straws. You can't suck the same amount of fluid through a small straw, in the same amount of time, with the same amount of pressure, as you can a larger straw. That said, you can suck the same amount of fluid through a larger straw, at a lesser pressure than a smaller straw. Boost, believe it or not, is NOT our friend in building a motor, boost is restriction that happens between the discharge of the turbo, and the combustion chamber. This includes the head, charge pipes, intercooler, etc... When we are looking at an engine thats built to support 800whp, we need a damn efficient head, thats not going to hinder our flow.
Like i said before, this is ONLY for the turbos I know Cardelino is considering, which is the ONLY reason I asked it in here. It would be a plain waste of money for me to go out, on my stock turbo and do all this, and I would likely lose a crap ton of power up top. Hope this makes sense, and was somewhat educational.
Will, I know you know your stuff, and its cool that you're questioning, because we all learn that way, but sometimes, its best to take someone's word when they have the experience. But, take the proof I have attempted to provide, as you may, and there will be alot more proof hitting the market in the next year.
Also, I will say this, the LNF market has been rather slow. We are finally figuring out what makes these motors go boom, and we are finally getting people to build their motors. There is literally less Sol/Sky guys building their motor, than I have fingers on one hand, and the majority of them are building the motor for reliability's sake. The engine is rather far from new. the majority of the components were engineered alongside the LSJ, and the LE5. The technology from both are present in the LNF, except that the LNF gets a **** blocking DI system, that ruins your day when you wanna make gobs of power. Besides that, all principles of a normal motor still stand.
mkriebs is correct in that when you have a polished port that you have maximized flow the next restriction is the valve openings. The quick way to help this is with higher lift. if you have not run out of lift, then adding 1mm bigger diameter valves is a lot of work to get the same results you could get by increasing the lift. This works for both inlet and exhaust.
The further you deviate from a stock motor, the more likely something is going to go wrong. And for what? Is the OP really going to slap on a 66 lb/min turbo (GT35 sized)? If it's GT30 or under, there are unjustified costs. This is for someone that is apparently putting this all on credit, since he said before that he couldn't afford to rebuild the motor, and was going to sell the car with a busted motor. He's not gonna shell out for a big turbo setup.
And good god, I still can't believe he's being advised to do all of this, yet there may have been valve to piston contact, and the stock valves are going to get re-used.
there is more to this blowing through the straw, for instance, whats on the other side of the straw. Bigger valves only mean that there is less area around the valve inside the bore. a stock size that is un shrouded will flow better than one that is oversized and isn't.
Yeah, I was pissed. I borrowed a 36mm yesterday, but it was too short (regular socket, not an axle one). Listened to these idiots, so I went out this morning and got the wrong damn socket... One day i'll learn.
Hmm, I swear a 35mm worked on my car, thanks for calling me an idiot, really makes me feel good. Maybe do your own ******* research than taking the advice of people on the internet. Maybe your the idiot? Gimme a break dude.
Like I said, my fault for listening to people on here. I know better.
"mkriebs is correct in that when you have a polished port that you have maximized flow the next restriction is the valve openings. The quick way to help this is with higher lift. if you have not run out of lift, then adding 1mm bigger diameter valves is a lot of work to get the same results you could get by increasing the lift. This works for both inlet and exhaust. "
Now, am I saying that you would leave the stock port size and shape? No. You guys are ridiculous. I am sure you have both built LNFs that make 600+ hp, that have fully built heads, right? Gimme a break, and quit being douche bag know it alls about everything.
Essentially, since we can't run cams, the next step would be the valves. So, good luck on your stock valves, that are likely bent.
In all seriousness man you can't get mad at them you didn't do your due diligence, like the saying want it done right do it yourself.
Card's turbo selection, seems to point that he is shooting north of 500whp, and the fact he is sleeving the motor, and building everything now, leads me to believe he might have even higher goals down the road. To get to even 500, he is going to need, at a minimum, a pretty damn good port and polish. To get over 600 (which, he may not be wanting, maybe I should have clarified and asked exactly what his goals are), he is going to need a set of yet non existent cams, or a valve job. So, there are his options, and since no one wants to make cams for the LNF, I would say the valve job is his only choice.
Now... to quote Mr Bill Duncan, the engineer in charge of these engines, just a few posts up from yours:
Your best bet is to ignore me. You take the internet way to seriously. I don't.
Like I said, my fault. I made it work anyway, it's done. I'll go get another axle socket before i re-install, just adds to my collection anyway.
Yep, definitely have sand in my Vagina. Its ridiculous talking to people on this site, because you can never make a point. Guess it all depends on the engine's owners end goals. By the way it looks (his turbo selection), he has some very lofty goals, that I don't see happening without a very built head. Thats all I was saying, and then i get criticized for saying that?
Last edited by ItalianJoe1; Apr 2, 2010 at 06:01 PM. Reason: Automerged Doublepost
