LNF Wiseco Pistons stock rods
Are Wiseco LNF pistons compatible with stock rods? There is a thread from a while back where MattM says they are not. Should the stock rods handle a maxed out ZFR 6758/E47...what is that ~450whp?
Factory LNF rods have a tapered small end and the pistons are tapered to match. The aftermarket rods and pistons currently available do not have this taper. You wouldn't be able to run a stock LNF piston on a K1 rod or a Wiseco LNF piston with a stock LNF rod. However, you can run a Wiseco LNF piston with a stock LSJ rod.
I am hesitant to push it beyond 24psi due to the risk of damaging the head/cylinder if a piston breaks up. I am thinking just replace the weakest link in this engine and push it. I have been running 24psi/e47 for 2 years with no problems, but now with the 6758 I just think its a waste at 24psi.
If you have a shitty tuner, even the best motor won't last.
I thought the pistons were the weak point though? Will they work with stock rods?
Eh...maybe I will just hold off on digging into the motor and keep the power close to where its at. That $$$$ will go a long way for a trans swap...and I think that will net me a much lower et than a little extra power.
I do agree tho there's no point throwing in pistons on stock rods why pay to get machining and everything to put stock parts in
To answer the original question, you can run Wiseco pistons on stock rods. I just finished my build with this.
The reason I went this route was that the stock pistons are suseptable to ring land failures even at stock levels and I don't need more than 350hp. My engine was also apart so making the change was easy.
Daniel
Daniel
The following 2 users liked this post by TurboWood:
hhrfreek (09-07-2015),
soundjunky (09-15-2015)
Daniel
Daniel
Not everyone wants 600hp. Personally a waste of money in my eyes. I'm not into highway pulls and straight line racing with this car. Take it on a road corse and you will quickly see with a good driver 350-400whp is plenty ro be competitive and you don't need more to make it fun either.
I agree with everyone saying when your engine's apart anyway, upgrade all that you can. I only had spun bearings but once the engine was apart I had them put in Wiseco pistons and ZZP forged rods. Parts are relatively cheap when compared to labor of tearing the engine apart multiple times.
But also listen to the folks who say do your tranny first. That was the first thing to go on mine once the engine was back together and I was running 27psi on the 6758 and E47... (even at altitude)
Also-op I had the same question as you with the Pistons. Built many small block mopars, and small block chevy's and have seen stock rods take a lot of punishment. My only concern would be that usually forged pistons are heavier and swinging that much more weight on the lnf stock rods over time may be too much to ask. If you are staying under 6500 I don't think you will have issues. But most guys when building these motors are also adding bigger turbos that like higher rpm so it's just good insurance. But I don't know a ton about these little motors, just my opinion.
Who was your tuner?
I would think upgrading rods would be under the grey area of "if it's apart, why not?" - but that being said, from all I have read here the ringlands, and piston skirt are the two areas which get damaged first (so it is all in the piston; the latter scores cylinder walls, while the former gets plain nasty fast).
Any aftermarket piston would be compatible with OEM rods - as a matter of fact, aftermarket rods are patterned after OEM rods - so to suggest one wouldn't work with the other seems kinda... retarded to me.
at least every time I have seen side by side weight pictures (from people who went hte distance to share this - they all showed a weight savings);
Plus, aftermarket pistons generally can be lightened to aid in balancing.
Lighter rods & pistons, allow the engine to change rev's easier & quicker...
Ok, sorry for the tangent guys;
Does anyone know who's rods are being sold as "ZZP rods"?
It stands to reason that they are just 'brand x' rods, being sold as ZZP parts...
I was doing a search the other week to see who the manufacturers of aftermarket rods for us were, and ZZP's looked very much like the most common one's I was seeing out there...
I only ask because I'm curious.
I'd love to get a set of Carrillo's, but those aren't exactly in the cards right now...
Cirilla's
OPEN NOW
Today:10:00 am - 12:00 am
6128 Covington Rd,
Fort Wayne, IN 46804
(260) 436-0033
Sound junky- I have no idea what the weights are I was just going with my prior experience with motors. From my experience forged are heavier than cast or hyperutectic (probably miss spelled that) piston to piston, but forged are always stronger when it comes to detonation. One way to combat this say on a sbc would be to run a longer rod and shorter piston. I know nothing about the weight of lnf stuff.
I would take the time to send it out for balancing if changing any of the weights.
