Low cost clutch upgrade?
Old Oct 4, 2009 | 07:06 AM
sporttintturbo's Avatar
we will find out in due time lol. i got a stage 4 clutchmasters going in and will have 400-425 whp. im expecing axles first.
Old Oct 4, 2009 | 09:36 AM
mongorat427's Avatar
Originally Posted by TurboTechRacing
We have the Exedy Hyper Single on sale this weekend for ONLY $999.99!
http://www.turbotechracing.com/produ...idproduct=4912
NO other discounts, of any kind, will be accepted on this item.
How does this compare with the Spec stage 3 ? I need one thats not going to kill my repaired knee.
Old Oct 4, 2009 | 09:39 AM
TurboTechRacing's Avatar
The only SPEC rpoduct to compate apples to apples:
SPEC Stage 3+ with their Aluminum fhywheel. This would be a close comparison
Old Oct 4, 2009 | 07:54 PM
IsItFast?'s Avatar
The hyper single is really nice... I have one (going to put it in next weekend) but I am a little concerned.. In the documentation that comes with the hypersingle (directly from Excedy), it states "MAX torque is 345 lb/Ft". Im already putting down more than that. I guess only time will tell if this was $1100 well spent!
Old Oct 4, 2009 | 08:55 PM
Balento18's Avatar
trying to find clutch warm up sticky, can someone tell me where I can see that?
thanks
Old Oct 4, 2009 | 09:13 PM
Projekt's Avatar
393 wtq 12,000 KMS stock clutch holds fine
learn to drive
Old Oct 5, 2009 | 03:55 AM
agent007kimball's Avatar
learn to drive
You must have a freakishly strong stock clutch or you constantly baby your car. It certainly has nothing with learning how to drive. I have owned and regularly driven 10,11 and 12 second manual transmission cars for years and I would get 50,000 miles or more out of those clutches before even a hint of slip showed up...and those were driven quite hard.
Once the tune was put on the SS/TC, it just over powers the clutch when full boost kicks in. I think the stock clutch just isnt that robust in terms of handling torque over 340ish.
What mods do you have for 393 tq? Please don't say just a tune....I would like to see a different dyno do the run if that is the case.
Old Oct 5, 2009 | 06:21 PM
MaxVQ35DE's Avatar
learn to drive
seriously, the rpm where you would make that torque would be the same rpm that would cause epic slippage on the clutch on the street.... Learn to drive my ass more like Learn to drive my ass to a realistic dyno.
Roll into throttle 2nd gear 3500rpm... spins
roll into 3rd at 3300, slips till 4k
roll into 4th at 3700 slips to 4k
The slippage happens 100% of the time when cooler than 65 degrees and RARELY when above 80
This is happening because of 2 variables
-The clutch takes a while to warm up and the material cant handle that much torque until really hot. My commute is 20 miles and its only grabby for the last 2 miles.
-The car is developing a whole hell of alot more torque when its chilly out.
but, my clutch must be glazed/shotbecause it slips even with the mild trifecta tune.
Ill be running stock tune until the exedy is in and broken in.
The capacity for the LNF clutch is probably 300lbft to the wheels. Too bad the Kbodys have such a superior drivetrain, RWD/trans/clutch oh well....
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
OPCrer
Sep 27, 2015 08:11 PM
