Machine gun like backfiring at wot
Bacjfiring like crazy at wot sounds like a machine gun shooting out the tail pipe
Check engine light started flashing for 5 seconds then went off
Any ideas?
Any ideas?
did it sound like cannons?
why have guns anymore when u can just hit two step - YouTube
no wait you said machine gun fire... like this?
Fun on the blvd - YouTube
Not sure but you did you try to NLS before the car was warmed up to at least 180F Coolant temp? That will cause that. Also, you should check your plug gap just to eliminate that.
If your car is tuned, get with your tuner and send a log of it happening. It *could* be something like injection window misfire.
I agree that it does sound like injectors but check the other stuff just to eliminate them.
More like the second vid, dunno if I've got flames poplin out the tail pipe tho lol
I have never tried to nls
I have owned the car for 20 000km I've never changed the plugs car has 60000km on it so not sure if there original or not
Here's a pic of the plugs
There was some water in the # 1 plug cavity, not a lot but was wet
Can you take a vid and post? Could be a seal, could be the plugs(blowout) or tune(even GMs1). If you need help with installing seals let me know. Just did mine last weekend and did it in 2 hours.
Had the machine gun backfire, found wires on map exposed and shorting on coldside charge pipe. This caused 1st o2 sensor on turbo to go bad. Fixed wires, changed plugs and o2 sensor and all is well!
