Meth/LNF Engine
I pour out a 1/3 of a jug of advanced auto blue wiper fluid which is roughly 60%water 40%meth, then I add 5 bottles of heet. It gives me like about a 70%meth 30% water mix. Once tuned though its easy you just have to keep your mixture the same and you wont run into problems.
Mix... Some people mix their own some use windshield washer fluid. Devils own makes a premix. You can find it elsewhere also. It should always be mixed with highly filtered or distilled water, the water helps also.
You can certainly buy their mix, ive used it plenty of times and it works well. A lot of people run the washer fluid method since you don't have to wait for more to show up and you can also refill on the road at anytime!! For some people, this is necessary!
Yea true. I run either one. I know some people care cor some reason. They hate windshield washer fluid going into their motor. Ahh it doesn't matter, either way the mix contains water and meth, if you don't like the color you can change to a different brand haha.
No stations in Florida really we have like 3 in the entire state LOL.
Last edited by Terminator2; Oct 21, 2010 at 03:47 PM. Reason: Automerged Doublepost
I did not see ZZPs dyno sheets with meth. I never knew they ran meth in the car. I know they made 351 whp on E-85. I have one car running a 3 gph 50/50 water/meth nozzle and 50/50 E-85 and 91 octane. He will soon be strait E-85 and the water/meth.
And we will be going back for more! I know we can equal that three extra horses
Its also even colder now, IM sure that alone will make a difference lol
Last edited by 09whteSSpssssh; Oct 21, 2010 at 04:06 PM. Reason: Automerged Doublepost
@ Oscar - Considering you showed up to the dyno, ran it 3x back to back and all were right on top of each other AND I didn't touch a thing while you were there....There's some more on the table
With bolt ons and a tune I put down 311whp on this dyno, Oscar put down 328, same mods and my tune, with Meth being the difference. I also realize the E85 or blend has a very similar effect, Im not denying that. But that is my point, you are going to get similar results based on the 3whp difference between Oscar and ZZP, both are load dyno's, not Dynojets.
We plan on trying a straight E85 tune or E blend on his car and we will be running on the same dyno as before. Those results over the Meth results should certainly be a good test
When you get it as strong on E85 as it is on E48 let me know how you do it. Mine pulls much harder & more dependably on the E48. Too much fuel in too small an injection window IMO on E85. >70%E here is slower by .4 sec 60-100, same boost DAL's & timing >25*.
Maybe the 4.45 axle ala ZZP unloads it enough that it pulls fine, I can only post my experience with the stock axle ratio.
Any other stock turbo's pulling a 4.4sec 60-100 without meth? (or without the bottle? lol) I should drive up to ZZP and dyno someday.
