meth nossle
meth nossle
where do u guys have ur meth nossles mounted? i know in the cold side past the map, but do u have it on the side of the charge pipe facing the front on the car or on the side of it thats facing the drivers side?
i know weird question, but i cant decide which is more accessible and practical.
Cold side near the IC outlet is the best, gives the most time for cooling & mixing. The MAP sensor won't care if it gets wet, only the MAF sensor you need to worry about for that.
really and the meth in the mixture doesnt do any damage?
actually id assume not since u got a map in the intake manifold to so either way, one gets wet
So are you drilling directly into the charge pipes to install?
I'm buying one and knowing where to put the nozzle has plagued me. I keep debating on where.
I think I agree most with just after the IC outlet.
no i took my lower ic pipe to work today and got a bung tig welded in, also found out some other stuff while it was off, i dont like hahn charch pipe no more. found some rusting on the inside since its made of normal steel not alluminum or stainless. im sure meth wont do it good for rusting. i got the sandblaster to sandblast it and i sprayed the inside with galvinize (spelling) and repainted the outside. clear coat is drying as we speak, tuned out great, but im still worried about rust, will probably end up buying a different pipe down the road.
Unfortunate to hear about that lower cp rusting. I'm interested to see your setup with all this.
what buy charge pipe and welding the bung in there? would be to much of a hassle for just a bung. im thinking of buying a small tig welder though, so i dont have to get a guy to do it at work. now if i learned to work the pipe bender at work, then i could make the pipe and sell em. maybe someday ill do it.
