Meth with Stage 1, Good Combo?
"Truth.
The MMWA was written as a safe guard for people who want to buy a Fram oil filter instead of the OEM or if you want to use Hawk brake pads instead of OEM or a Royal Purple oil instead of OEM. It is 100% NOT for putting aftermarket intake systems, exhausts, intercoolers, etc. onto your car. I hate when people mention the MMWA like it justifies any modification you do to your car...it's NOT designed to protect against modifying. It's meant to protect against maintaining...nothing more"
just so you know - Fran oil filter is aftermarket, Hawk brake pads is aftermarket, Hahn intercooler is aftermarket, ZZP turbo is aftermartket..
food for thought - changing the brake pads to another manufacture, other than oem is modifying.. i can tell you over 1k court cases and claims regarding MMWA, so modifying any part on your car/truck is covered under MMWA.. "modifying = aftermarket"
Last edited by redstarpa69; May 18, 2010 at 04:34 PM. Reason: Automerged Doublepost
lol my car shows more then a degree of knock on stock tune or otherwise, on wot it doesnt at all though, just on light boost. both in +20 and -20, and how will running higher octane fuel make ur car run that much richer? then everyone going from normal gas to e85 would have problems.
i guess you haven't really read the MMWA, I know it by heart, I worked for the second largest law firm in US, who in fact had co-written most of the bill, which congress passed into law.. just food for thought.
true
So saying - It is 100% NOT for putting aftermarket intake systems, exhausts, intercoolers, etc. onto your car. are you sure?
true
ZING Thanks for the extra insight on this.
And sweetsandman isnt saying the higher octane will make u run richer, hes talkin bout the meth.
Food for though: I can assure you that GM and its hundreds of engineers will be able to find the slightest reason to blame your AEM intake, for example, for a blown piston or a shattered lifter or whatever the case may be and you as a consumer will have no way of disproving that without spending thousand upon thousands of dollars to pay someone to research and not to mention court and lawyer costs. So, with that, for any fool that thinks the MMWA is going to save your butt when you enhance the performance of your car and GM decides that they don't want to cover your damaged drivetrain...all I say is...you're in for a long ride with a shitty end...kinda like Avatar.
I don't know, but something don't sound right here. Your profile says you have a 2000 Pontiac Sunfire with a 2.4 liter motor. To the best of my knowledge, most of those motors had a 10 to 1 or higher compression ratio which should theoretically limit your boost. You also say you are running 26 lbs of boost with a GM stage 1 tune. Somebody correct me if I am wrong, but the only ECOTEC stage 1 kits that I know about are for the LNF and LSJ engines. I have the GM Stage 1 (19212670) kit with MAP sensors installed on my LNF Cobalt SS and it never seems to pull more than 23 lbs of boost. Time to put away your dog earred copy of Import Tuner and come back to the real world.
So your pretty much saying i am lying about the motor being on 26psi at peak and holding 24psi because yours doesn't?
are u guys seriously only getting 17whp tuning for meth? dyno guy around here says u can do 70+hp more on meth, and other places iv seen numbers with and without meth like 70+hp
It's more than 17 whp. .91 Lambda, ridiculous timing and lowered egt's are a+.
You do understand you can do [if you dont care too much about the longevity of your turbo] a dual injection point setup. One small fine nozzle pre-turbo and then your main pre-tb. With a high quality nozzle and a maxed out 250psi pump you can shift your entire compressor map around for delicious results.
devilsown...I know you're a great vendor and all...but are you going to cover the cost of repairs when he blows his motor running pig rich and knocking like a sonofabitch? Because GM sure won't
But seriously...these cars are sooooo touchy with even the slightest of mods that something like meth could really do some severe damage. It's not the colder IAT2s that you would have to worry about so much...it's the fact that you're running essentially race fuel everytime you put your foot down.
Seriously OP...tune for meth or don't run it at all. Even those crazy DSM guys know better than that (most of them).
Not running methanol injection can cause damage to these motors. With a properly setup system the raise in octane is actually very min. the decrease in inlet air temps reduces the need for octane that the engine requires. This is what makes methanol injection increase the reliability of a motor.
Example. both 400hp setups gen 2 3.8L that are turbocharged we usually run do14 on them. and on the gen3 3.8l with the eaton 90 we will run a do5. Night and day power increase with the gen 2 over the gen 3
I am personal not a big fan of pre turbo injection. If anyone does it i dont' recommend anything over a do2 nozzle. Yes you can shift the compressor map but the big gain from it is your are able to start cooling the heat right at the source. but the down side is you can tear up a turbo if not done properly.
Honesty turbo ed apps to to make more power with methanol injection. Most supercharged apps don't allow for us to put the nozzles in the optom spot. After the heat source. Or they are so close to the intake we don't' have the the time for the mixture to absorb. So we have to run smaller nozzles on them.
The second part honestly surprises me a lot...I would think that with the excessive amount of heat soak that the SC guys suffer from that it would benefit them exponentially (although I don't know how our setups compare to those 3.8 setups). I know our IATs don't get nearly as high as the SC guys see but maybe I'll have to run some meth and do some testing on the dyno in the fall.
PS....what do you mean "done with your car"?
Last edited by Sweetsandman; May 20, 2010 at 08:15 AM. Reason: Automerged Doublepost
Another reason for spraying pre-turbo. That's on my solstice after a couple hard pulls.
http://www.hardkore.org/fuckmylife.jpg
Don't get me wrong about pre turbo injection. yes it really can make a huge decrease in temps. Just care needs to be done when setting eveything up. People need to avoid cheap pumps the 60psi diy style pump will not cut it. It's vital to get small droplets so you don't distort the turbo. Another things is to keep from damaging the wheel is you have to start spraying on it before its already red hot.
yes supercharged apps do heat soak pretty bad. But since most of the time we are spraying threw the blower we are limited by the amount of fluid we can get threw because most blower can only move x amount of air per rev. Porting them, pulling them does not adjust this.
