mobil 1 filter
Old Nov 20, 2010 | 12:25 AM
cresintern's Avatar
mobil 1 filter
Any thoughts on using a mobil 1 filter instead of the ac delco filter on sstc??
Old Nov 20, 2010 | 01:52 PM
09BlueBaltSS's Avatar
IDK. The only ones ive ever used is AC Delco and PureOne. Mobil1 should be good stuff tho
Old Nov 20, 2010 | 02:13 PM
cmiller8006's Avatar
can't say it was a defect or improper instal but we had a cobalt come in with a blown motor and the tech just happened to take out the filter to look for metal and the nipple on the end was gone. Stick with delco. But do like I do there is usually deals where you buy the oil change jug and getthe mobil one filter free, take it lol. I have a stack of em.
Old Nov 20, 2010 | 02:39 PM
The stores in my area dont carry the M1 filter for my car and they wont order it without me having to pay extra. I almost always find a deal with a free PureOne filter tho
Old Nov 20, 2010 | 06:14 PM
Malaclypse's Avatar
Stick with AC Delco.. Its a perfectly good filter.. better than the majority of other brands... that and its what the manufacturer calls for.
Old Nov 20, 2010 | 08:00 PM
Cefaln452's Avatar
go WIX if anything, they make racing filters
Old Nov 20, 2010 | 08:03 PM
biniecki's Avatar
I always use the Fram filter. Not really much choice of good filters in my area.
Old Nov 20, 2010 | 08:12 PM
Cefaln452's Avatar
id advise from staying away from fram. reasoning being (not that it will happen to a normal car) but the filters collapse and they do a terrible job of filtering. search about it on google if you dont believe me.
Old Nov 20, 2010 | 09:16 PM
reddevil's Avatar
My original gm filter was collapsed 1st oil change.. Here is what i figured out, the orings stick on the ends and when you unscrew the filter cap it twists the filter and gives a collapsed look, so infact the filter was fine before removing it..I suspect this is probably what tore the end off the filter end mentioned above..
Old Nov 20, 2010 | 09:41 PM
The tech at work said that they crinkle like that because they need to seal good and they are supposed to do that.
Old Nov 20, 2010 | 09:57 PM
Cefaln452's Avatar
Google Image Result for http://www.handa-accessories.com/15400.jpg
just for reference
Old Nov 20, 2010 | 09:59 PM
hook's Avatar
I only ever used the k&n filter. however since i have heard that mobil 1 makes a filter i have made the switch. much better flow over stock.
Old Nov 20, 2010 | 10:05 PM
GTO 1's Avatar
Use OEM.
GTO 1
Old Nov 20, 2010 | 10:19 PM
Might have better flow, but what about filtering capabilities? I will almost pit money on it that the ac delco filters better.
Old Nov 20, 2010 | 11:41 PM
gone_in_10_sec's Avatar
Damm, I knew it FRAN does s*x, does anyone know all P/N for M1, WIX, K&N, AC Delco and PureOne?
could someone post them up thanks.. found most.. sorry for the thread jack..
K&N: HP-7000
Hastings: HAF-LF548
ACDElco: PF457G
Wix: 57082
but i did find this: OIL FILTER RELOCATION KIT COBALT SS
Old Nov 20, 2010 | 11:46 PM
CordiaDOHC's Avatar
I ran a fram once when I didnt have time to go the dealer. I took out the fram at 2500 miles due to it bothering me and wanting to switch to a slightly heavier oil. And the fram was already coming apart... Glad I didnt go 3500-5000 miles on it!!
Sticking to the delco ones despite the price
Old Nov 21, 2010 | 10:04 AM
hook's Avatar
This is also more than twice over stock. much better flow. and much better filtering capabilities
K&N: HP-7000
Hastings: HAF-LF548
ACDElco: PF457G
Wix: 57082
I do believe mobil one is MC-151
Old Nov 21, 2010 | 10:23 AM
Wangspeed's Avatar
Purolator Pureone for me. Not cheap, but excellent filtering.
Old Nov 21, 2010 | 10:44 AM
Cefaln452's Avatar
^^^ thats even worst lol.
Old Nov 21, 2010 | 02:41 PM
Malaclypse's Avatar
So explain how its physically possible to get greater flow AND better filtering?
Better filtering will always reduce flow because the pores in the filter media are smaller. Surface area can only be affected by the number of pleats of material in the filter. The filter size can't be increased because of hte size constraints of our filter housing.
Basically, anyone with oil or oil filter questions should go here: www.bobistheoilguy.com
Old Nov 21, 2010 | 03:57 PM
flipping thru the bobistheoilguy site. and found a few good posts to read on a 09 LNF
Mobil1 5W-30, 6752 miles, 2009 Chevy Cobalt SS
Pronto PO5436 cartridge filter (ION, Cobalt, etc)
Old Nov 21, 2010 | 04:38 PM
[QUOTE=hook;5388595]This is also more than twice over stock. much better flow. and much better filtering capabilities
Show me where you find this info.
Old Nov 21, 2010 | 07:29 PM
efactor's Avatar
because they are Made in China. That's why I stay away from Fram. Stick with ACDelco, Bosch makes good filters also.
Old Nov 21, 2010 | 07:33 PM
Chandler's Avatar
to answer the original question, mobil 1 filter is fine.
Old Nov 21, 2010 | 07:57 PM
Sizzle06's Avatar
wix for me and used a k&n once with no problems
