my new hahn intake
Old Mar 17, 2009 | 01:46 AM
jaygo7007's Avatar
Talking my new hahn intake
finally installed the hahn intake in the tc. and i love it every bit. i believe theres no need for a bov. but heres a clip tell me what you think of it
http://www.youtube.com/watch?v=N0-L2qTdr78
Old Mar 17, 2009 | 09:08 PM
NarutoDF's Avatar
i have it on mine and yes. it sounds so beast lol. Even when you start the car at idle when you open the hood its so much louder.
Old Mar 17, 2009 | 09:11 PM
TurboTechRacing's Avatar
Very nice, high quality parts
Old Mar 17, 2009 | 09:17 PM
NarutoDF's Avatar
even though the car still has the relearn feature. to me it seems as though it still pulls harder then it did before. The mechanic i was talking to said that the relearn feature everyones talking about may be refering the the torque converter or something along those lines. Iv also been hearing from some posts that even though theres a relearn feature you just achieve 260/260 easier then you would stock. Either way im tuning it hopefull by the end of may . Maybe even june because i here theres a stimulouse check coming lol.
BIGTAG's Avatar
yeah i loved the way my car sounded when i put mine on
Old Mar 17, 2009 | 09:19 PM
^^^ It does pull harder... What everyone forgets is the ECU ONLY limits PEAK power.
The intake and other mods will create more low end power.
For example:
Before (stock) at 4,000 RPM you made 200 WHP
After, with and intake at 4,000 RPM you make 210 HP
The computer cannot tune this back. So it is not just about peak power You still gain...
That is why you have to look at the "area under the curve", before and after; the more area, the better.... (Calculus)
Old Mar 17, 2009 | 09:26 PM
NarutoDF's Avatar
aha. nice, i knew there had to be something behind it. Because it wouldt make sense that putting 3 mods on your car stock wouldt help. What about when i get into my 3rd or 4th gear? when you say peak do you mean the higher RPMS?
Old Mar 17, 2009 | 09:32 PM
Peak meaning the top power it puts out... It will never go above 260, unless you tune the ECU to allow it... (But as stated above you will gain all the way up)
Old Mar 18, 2009 | 08:51 PM
tomj77's Avatar
i just got my intake today, got it in victory red, havent installed it yet, but it looks amazing. red on a black car, yummy. lol
Old Mar 19, 2009 | 01:10 AM
09SportRedSS's Avatar
hell yea i love this intake it sounds so good and i think it was worth waiting 3 weeks to get
Old Mar 19, 2009 | 08:36 PM
tomj77's Avatar
i installed mine today, the only complaint i have is the crappy clamps. i broke one, now i gotta take it off and change it. lol other than that it sounds awesome, love the air sucking sound and the blowoff. way louder. why get a bov when this works so good and sounds so good. turbo sounds alot louder to. and it does have more kick. yay, now for a charge pipe.
Old Mar 19, 2009 | 09:08 PM
With the Intake and the charge tubes the under the hood looks awesome.
Make sure you all have a Turbo Tech Racing Upper engine mount also... Keep the shifts firm, and keep the engine from "flopping around"
Old Mar 19, 2009 | 09:12 PM
ericgt79's Avatar
if you starteg with hahn parts you should finish with hahn parts...dont cheap out on your car..not that dejon is a bad company i have their spring but i just like all my pieces to match and dejons piping is routed diff than hahns and i think you would want to make sure the paints match up the same.
Old Mar 19, 2009 | 09:13 PM
Good points... Plus you know Hahn will always be around they have been around for 20+ years...
Old Mar 19, 2009 | 10:07 PM
i was thinking the exact same thing next for me is exhaust and and charging pipe
Old Mar 19, 2009 | 10:25 PM
citystars136's Avatar
I love mine to, sounds frigen awsome..
Old Mar 19, 2009 | 10:28 PM
did you test it with the light out still?
Old Mar 20, 2009 | 05:10 PM
tomj77's Avatar
crap no one around here will think i got an ss/sc anymore now that u can hear the turbo and blow off.
Old Mar 20, 2009 | 05:39 PM
reign1's Avatar
u guys are ********. lol
now i got to buy mine. think ill be doing that tomorrow....
hmmmmm what would look good on a black and white themed LNF?
Old Mar 20, 2009 | 06:07 PM
xray_racer's Avatar
So I know this is probably a dumb question but why would you want solid engine mounts? Wouldn't a little bit of give take some stress off of other components like the transmission and axles? Isn't that essentially what an engine torque dampener does? Please help me understand. Thanks in advance.
Old Mar 20, 2009 | 06:13 PM
reign1's Avatar
there is no TD for the LNF buddy
Old Mar 20, 2009 | 06:17 PM
As the engine moves, it puts stress on items like your downpipe, and may cause them to crack (as some have had)
Also engine movement = loss torque... You can utilize that torque and put it through the drive train.
Old Mar 20, 2009 | 06:20 PM
reign1's Avatar
TTR ill b buying the Intake prolly tomorrow from Hahn.
any advice?
Old Mar 20, 2009 | 06:22 PM
xray_racer's Avatar
Makes sense to me. Do you know what good an etd does then? I've read some people saying it helps reduce wheel hop, but I dunno.
Old Mar 20, 2009 | 06:43 PM
reign1's Avatar
yes it does.
just think of it as a shock(like suspension) for ur engine.
it stops the engine from moving so much. but gives it just enough so u dont wheel hop and snap an axle. btw ur in the wrong section
