my Psykotoon
my Psykotoon
Had a shitty dyno machine but the TQ was amazing. lol
Intake, Catless DP, and tune from Psykostevo.
Torque was 340. need another dyno for the HP
Need chargepiping soon though
Spiking 25 PSI while holding 22-23.
best $$$ Ive spent.
best $$$ Ive spent.
What did your car dyno stock on that dyno? What HP did it make tuned? It is always best to get a baseline number so you can compare.
Who is tuning your car?
Last edited by Terminator2; Apr 20, 2009 at 12:22 PM. Reason: Automerged Doublepost
the dyno was rediculous let alone they were pushing the car. they only pushed it to like 5500 RPMS b4 lettig off
he can tune you if u get some people together woh wants it. hell fly out
the DYNO DYNAMICS ssaid 238 WHP which is totall bullshit
but my TQ was high as hell .
AFR was 12.5 almost all the way accross the board
hows the car driving, big diffrence?
i get torque steer in 3rd
lol.
i can break the tread loose in 3rd
and i cant hit 25 PSI by 2500 RPMS. so u are put into ur seat.
i got to learn how ot launch the car allllll over again. lol
lol.
the 238 was at what rpm?
my TQ is not 215. lol
my HP was 238. which is way ow considering all the stage 2 balts that had same bolt ons were like 15 HP different from eachother.
and a 20 HP gain from going catless on a SC
it was wack
it was wack
It must have been at 5800 RPMs not you torque peak. 215 wtrq at 5800 means 237 whp Hp = Trq X RPM / 5250 Ex. 215 X 5800 / 5250 = 237.
Your car should have made way more than 238 if an intake only TC made 212. There should be a 50 whp difference not 25 whp. Get you car tested on a another dyno like a dynojet. If you dont make close to 300 whp on there check your tune. Stevo's tunes seem to makes a lot of midrange torque but not a ton of top end Hp. Results vary but I have seen at least 6 dyno sheets from car he has tuned and the all make really good low end and midrange but most seem to fall off real hard above 5800 or so, and it is not just running out of turbo up top look. I still have power all the way to 6800 RPMS.
Tune and mods SAE.
Stock vs tuned SAE. Note that the motor cannot breathe up high. My tune is almost the same on all runs. We pulled a couple degrees of timing out with the boltons.
Tune and mods SAE.
you dont need to hold it to redline though every time though man
at least not to the rev limiter.
my limiter is at 6700RPMS
what i'm saying is based off of the 238 hp at that rpm, the torque reading would have been 215. Not saying that you actually have 215 tq. the dyno seems very off.
It hit it really fast and I wanted to make sure the car pulled well all they way to the fuel cut. I am giong to pull it to 7400 next time because I hate the power drop from 1st to 2nd the RPMs go from 6800 down to 3500 and the cars bogs for a second. I lift when I shift BTW. I dont want to strain the heck out of my car and it goes against everything I know about driving a stick shift. I was watching the speedometer on the dyno and made it to 111 mph but the car said 104 The cars speedo is wrong. I did some calcualtions and it is definately not accurate as you accelerate it runs slow. It is accurate when cruising but does not keep up while you accelerate. Kinda weird and I know for a fact that I am going faster than 97 mph at 6300 in 3rd. It is 103 BTW. I am not sure if everybody's is like this but mine is.
