My Turbo turned into a Supercharger
#127
mother of pearl... lol I will check the charge pipes and intercooler and take tons of pics tomorrow.. BUT YOU GUYS MY COBALT IS FROM HEAVEN LOL no but ever since i installed the downpipe my car would push 14lbs like normal.... UNTILL I HIT 5KRPM THEN it would jump to 17!!! NOW I GOT A CANNED TUNE FROM ZZP AT 22 PSI AND I PUSH 24 UNTILL 5KRPM THEN I ROCKET TO 27PSI..... Did that do the damage??? My car has always jumped 2-3 psi after 5k.... Is that normal???
#132
Yea, I would guess that too but its awful loud, man. I could see it being that loud if op was hanging out the passenger window but if it is a massive boost leak the noise will be amplified.
#134
whats holding and whats spiking?? I dont controll it lol my car has always done it i just thought it was "the one" or something idkk???? theres always those good and bad motors of every motor!! could a boost leak be causing all of this and my turb be ok?,,,
#135
Could a boost leak be doing this, yes. But we wont know until you check out your ic and charge pipe.
#136
Then why is my car spiking at 24 psi then when i go past 5 thousand rpms it jumps to 27 and stays there.... and it smells like gas not oil boy!
#140
Normally, if it was just that sound, I'd think it was a turbo bearing going.
A few years ago though, when I broke my stock IC, I had something similar happen to what the OP is talking about. The chunk that broke out of the intercooler was so big that you could hear the turbo spinning up quite a bit to try to get the airflow to the engine. The car would barely move under its own power and would go limp to a standstill.
I can also say (from experience I'm sad to say) that from the two times I've had a cylinder go the smoke was white for some reason, not the blue that you'd think it would be. I'm not sure why, but I'm wondering if it has some thing to do with being a synthetic or something.
If the smoke is white, he could be overspinning and damaging the turbo due to it not having any boost backpressure buildup, and the car keeping the wastegate closed in an effort to get more air. I would stop driving the car immediately.
#141
I will.. It smells like gas so tomorrow im gonna let it warm up a bit rev it for a sec and let some fresh **** come out the back and get a good fresh smell hahahahaha Then I will take the bumper off and the ic and both charge pipes and check them all for cracks... I have money to replace them all just hoping it isnt the turbo.. You have been such a big help man! thanks so much. tear down begins tomorrow
#142
If the smoke is white, he could be overspinning and damaging the turbo due to it not having any boost backpressure buildup and the car keeping the wastegate closed in an effort to get more air.
So your telling me your intercooler was so messed up (possibly like mine) that the turbo is spinning and thats what the loud noise is? cause it is just trying to get air? Ill be on my way to zzp tomorrow after noon and get a new ic if thats all the problem is... Im so not hoping a turbo..
#144
Tune sounds to crazy, my car spikes like 25-26 and holds at 23-24 but all ways falls off when it can't hold anymore. Gaining boost on top end is weird lol
#145
#146
I will not be spinning it anymore then! fuuuccck that! do you think it is still okay??? I plan on taking everything off tomrrow and plan on seeing a fucked up intercooler!
#148
After my incident, mine lasted for a couple more years (tuned) before the bearing/seals went. I only tried driving it about a quarter mile, to get to a parking lot where I could get towed from though. I haven't read the whole thread, but I don't know how much you've driven on it like this.
