Need another engine: LNF again or LDK?
Old Nov 10, 2017 | 04:49 PM
Julien Scherer's Avatar
Need another engine: LNF again or LDK/LHU
So my current LNF blew up pistons rings. I did a leakdown test and the results were heartbreaking:
Cyl 1 10% leak
Cyl 2 70% leak
Cyl 3 30% leak
Cyl 4 80% leak
The car was running a trifecta tune when I bought it but it was already too late when I immediately change it for HP Tuner.
So I'm considering to change my engine but I want to know if I should buy another LNF or go with LDK/LHU. Since I don't know the pros and cons of both engines, I'm asking here for info before buying one or the other.
Old Nov 10, 2017 | 05:18 PM
exninja's Avatar
Advantages of lnf over ldk:
1. Rod strength (maybe)
That's about it.
Old Nov 10, 2017 | 10:47 PM
63 Nova SS's Avatar
^ this
Old Nov 11, 2017 | 04:13 AM
slapbetcommissioner's Avatar
Advantage of ldk over lnf
1. Block strength no sleeves.
solution, ldk with forged rods.
Old Nov 11, 2017 | 09:41 AM
exninja's Avatar
Yeah, I didn't mention advantages of ldk over lnf. There are a few. Better casting is huge.
Old Nov 11, 2017 | 11:38 AM
Ok so LDK is a better option. At my range of power (380 hp/410tq 26 psi hptuner), do you think the rods/pistons will hold on? How much power do you think I can reach before having to change them?
Old Nov 11, 2017 | 12:22 PM
cw383's Avatar
ZZP said rods started bending on (some) LDK's around 400. You can find LNF rods on Ebay for cheap, but the bottom end drop, head removal with new gasket and cam reset is more then most on here would like to deal with.
Old Nov 11, 2017 | 02:18 PM
They are talking in whp on zzp, i'm talking in hp so my 380hp is around 320whp so I guess I don't have to worry if they say it's good to 400 whp
Old Nov 11, 2017 | 02:37 PM
tomj77's Avatar
at that hp u will be fine.
Old Nov 13, 2017 | 09:26 AM
umrdyldo's Avatar
Did you scope the cylinder? Did you do a compression test? Reason I ask is that you should do both because our valves have been known to be very dirty and cause leakage.
I see that you already get it, but just a reminder, do not run Trifecta when you get a new engine. It runs too rich and breaks ringlands.
Old Nov 14, 2017 | 08:38 PM
I did a compression test already:
Cyl 1 120
Cyl 2 80
Cyl 3 110
Cyl 4 70
I know that Trifecta is **** since a lot of years. I didn't know my car had TFT first when I bought it until I pressed on the cruise control button. I changed it the day after for a stock pcm and eventually for HP tuner.
Old Nov 15, 2017 | 11:37 AM
user 72239's Avatar
explain
Old Nov 15, 2017 | 03:04 PM
umrdyldo's Avatar
[/B]
explain
The general consensus was that with the excess fuel in the cylinder, the fuel washes the cylinder wall of oil lubrication and causes failure specifically at the rings. I have never seen what kind of timing Trifecta runs. But again, the OP is not the first or last Trifecta car to blow an engine.
Old Dec 8, 2017 | 03:48 AM
Steven Cox's Avatar
Hey I was wondering will a 2010 2.0 l lnf turbo ss motor fit in a 2010 colbalt Lt engine bay with out to much work and also when the engine is decelerating smoke blows out of engine what would the problem be
Old Dec 8, 2017 | 03:59 AM
cluelessk's Avatar
No.
Start a new thread for the second question.
