need answer quick
need answer quick
ok guys im jw if a aftermarket downpipe from a ss/sc will will fit a tc. i dont think it will but im jw if it will. and also and exhaust will fit from one to the other, correct?
coherent no. What do you even mean by THIS magnaflow? As long as your downpipe is made for the 08-09 SS/TC it will bolt up to the stock exhaust. A magnaflow muffler can be chopped into the system easily as long as it has a 2.5" inlet. But why???? You're better off going muffler delete or running 3" tubing from the downpipe back. I want to say there is going to be pretty much 0 gains from putting in a different muffler in the stock exhaust system.
the key here is that the 2 cars have 2 completely different manifolds. Meaning downpipes will not be interchangeable from one to the next. you have to get a downpipe specific to the car you have in this case.
didnt say it was a 2.5 buts thanks there.
yes that the answer i needed thank you. i am getting a cai 3'' dp and this exhaust then
NOTE: CIA has choices for downpipes, if you have emissions testing i would go with the high flow cat, otherwise catless. They also offer an exhaust system, 2.5" and 3". DON'T get the 2.5". Its more expensive than MES but i believe in trying to stick with one brand for my parts as much as possible so its all up to you.
The Rookie24
Sep 20, 2015 04:33 PM
