Need some help for smog please!
Old Feb 20, 2016 | 07:17 PM
ae_xiong's Avatar
So I currently have 2 CEL codes right now and they are P2261 and P0497. The 2261 is for "service turbo bpv" but when I took my stock bpv out, everything looked fine. No damage or tear anywhere! It also sounds the same, I did some research and came to the conclusion that if the stock bpv rubber is damaged or torn then you would get flutter and it will sound differently but mine still sounds the same as day one when I bought the car. A quick back track, car is fully bolted and has zfr upgrade running catless DP. Something to note about my car too is sometimes I would just get random backfires from driving normally and on cold start-ups my idle will go up to about 1.2k rpm and drop back down to like 800 and go back and fourth. I barely recently turned the cat warm up cycle back on.
The 407 is for evap purge low flow. I've changed that stupid solenoid or whatever it was called again twice already about 4-5 months ago. Could they go bad that quickly? I suppose that's why autozone put a lifetime warrenty on them. LOL
One last thing to note about the random backfires and weird cold start idling is when I reset my ecm, the car runs nice again. Then after a while when the codes come back it starts acting up again. I'm HP tuned btw. I don't think it's the tune of course because I just recently switched tuners and I was having the same issues on the previous tune as well. Any help is greatly appreciated!
Old Feb 20, 2016 | 09:50 PM
ae_xiong's Avatar
bump...
Old Feb 21, 2016 | 12:20 AM
tomj77's Avatar
its most likely ur bpv solenoid, the ecu has no way of seeing ur bpv isn't working, all it has going to it is a vac line, but the solenoid is controlled by ecu and if its having an issue it will throw a code. do like some of us do, save some money and eliminate it altogether.
tomj77's Avatar
I guess that wont help with the code though, just get all bpv codes disabled by hp tuners if that's what u have
Old Feb 21, 2016 | 12:22 AM
tomj77's Avatar
there is 2 evap solinoids, the one on the engine and the one in the charcoal canister under the car by the gas tank. probably need that one replaced.
Old Feb 21, 2016 | 12:30 AM
ae_xiong's Avatar
Never heard of that one under the gas tank. Any pics? Also, what do u mean by save up and eliminate it all together and delete the bpv codes? Would that make me fail my smog test because it's disabled? LOL Sorry, I'm pretty confused about this situation.
Old Feb 22, 2016 | 12:58 AM
ae_xiong's Avatar
bump...
revready
Jun 23, 2016 01:32 AM
Badbren_ss
Feb 20, 2016 04:49 PM
roadrunner132
Feb 18, 2016 07:36 PM
Glenn Rodgers
Feb 18, 2016 01:36 PM
jdbaugh1
Feb 17, 2016 08:16 PM
