Originally Posted by Neutrino
(Post 2432177)
First mod I would do to the SS/TC is BOV. Personally, I like em. I loved mine in the SRT and I miss it. Gotta love how everyones head rips around to look at you when you blow by them.
Fuck it dont listen to me, just throw a bov on. See what happens, so much for your no-lift-shift. Have fun with limp mode and no turbo whatsoever. and one more thing, when you bring your car to the dealer to get your recirc. put back on and everything that you prob fucked up fixed, guess what. OHHHH your warrenty has been voided that will be $2000 please? And while your at it... Might as well get the turbonator from ebay. You know, the supercharge any car product! That shit will make you flyyyyyyy |
srt-4 BOV are sneeze valves sound like crap
yeah....
You DON'T want a BOV (blow OFF valve) not BPV (bypass valve).
If you release air out of a BOV into the atmosphere/air your releasing air that was metered by the MAF or Mass Airflow Sensor and that air/fuel ratio is what the computer thinks is going into the engine....but WHOOPS you just released the air so hence more fuel goes in and causes rich craptastic running for a bit.... BPV's/what the SS/TC has, releases the air but they bypass it directly into the manifold again so the air stays in the engine and it runs fine. BOV's are for non MAF systems or high power applications.... So on a standard SS/TC if you want crappy performance just for a sound be my guest... ...sorry if any of thats been said.... |
i like my pshhh sound i guess imma ricer..........
Originally Posted by SS_carnatic
(Post 2509171)
Originally Posted by jimbos'ss
(Post 2509220)
shit i did my build all wrong, guess i'll start over............. you can use a BOV with a maf setup, like mike25 said, but it's gotta be before the maf sensor so only metered air gets in to the motor. note: the "So on a standard SS/TC" ie: I was talking about replacing the STOCK BPV with a BOV which is what the OP sounded like they were asking, Post MAF'ers slapping on BOV's would run like crap I'm not knocking BOV's just people who don't know how to use them, hell none of us like compressor surge, but you might as well do it right and not create any more problems.(talking generally, not stern forum voice) this is why we all need vent to atmosphere LOLZ.....http://www.youtube.com/watch?v=W_Qul7MiImk |
I've got compressor surge on my bypass valve right now lol
Anybody that went to the ny meeting can vouch for that |
bov
a blow off valve and bypass valve as basicaly the same thing, except the bypass valve has a rubber hose coming from where the air would get vented to atmosphere on a bov and it is connected just behind the air filter before it enters the turbo. when i had my talon it was done like that because otherwise it would run lean when it would blow off and the motor would struggle. but gm maf doesnt do that so it would peobably work fine just putting a bov on there instead, or just taking off the hose and plugging the hose on the intake with a small air filter or something. but it does cause ur turbo to spool all the way up again. but for myself who loves the sound of a spooling turbo and a blow off valve i dont mind, but if u wanna stay in boost and win that race, keep the bypass, u can hear it in the car somewhat anyway. unless u want to brag to the whole world u have a turbo
i totally replied to the wrong post here |
so if you didnt care about power or whatever and you just wanted to hear the blow off sound..how would you put one on the car if theres no mount for it..i jsut baught a 09 ss/tc and i have no clue where the stock bpv is..i would like to put a aftermarket on but i dont see where you'd put it..
^x2 !
To use a external BOV one must relocate the MAF element to a blow thru system. The MAf element must be closer to the throttle plate than the BOV.
THe MAf trasfer must be recalibrated via HPT to get this to work correctly. Our solstice has been this way for 20K miles, never had a CEL over it. New Era will have these blow thru MAF / BOV pipes availible within a month. THis is a solstice but here's what the pipes NewEra will have (prototypes likely next week some time) sound like External BOV LNF |
That camera can't even describe how good that BOV sounds...I'm sure it sounds A LOT better in person...I hate how cameras distort the sound of everything (exhaust, BOV, etc...)
Originally Posted by Magill8
(Post 2512728)
all bypass system guys...
hey, yep,
i been doin my research on this, and it's all a recurculatng bypass system. the wastegate, and the "bypass" is all internal, and therefoe goes back into the intake, so putting an aftermarket blowoff valve on this thing would screw you over, unless you move your air flow sensor, and then get it tuned to understand the "missing" air.... |
Originally Posted by badbaltguy
(Post 3052268)
hey, yep,
(Post 3052268)
hey, yep,
Correction, NewEra will have your correctly done BOV system. I just manufacture the goodies.
Originally Posted by FutureEcotecOwner
(Post 3052280)
Doesn't the SRT-4 work the same way? If so, then Mopar has a "block off plate" that all you do is mount it on the bypass valve, and with the holes in the "block off plate" it releases the compressed air into the atmosphere rather than back into the intake. It doesn't mess with the computer or throw codes or anything.
Originally Posted by peachpuff
(Post 3054103)
I dont believe the srt4 has a maf sensor, it uses map sensors and built in airflow tables to calculate airflow, so thats why the mopar plate doesnt affect anything.
Originally Posted by FuzzyBoost
(Post 2317059)
Good point im kicking myself for posting this right now sorry guys you can delete this post
(Post 3052268)
hey, yep,
i been doin my research on this, and it's all a recurculatng bypass system. the wastegate, and the "bypass" is all internal, and therefoe goes back into the intake, so putting an aftermarket blowoff valve on this thing would screw you over, unless you move your air flow sensor, and then get it tuned to understand the "missing" air.... the wastegate is basically a bypass for the exhaust gases to regulate the turbo. Basically when a certain pre-set boost limit is achieved, the valve opens so the gases bypass the turbo thus regulating boost. When the pressure drops the valve closes and the cycle starts over again (this all happens quickly) Edit: so not to confuse, it's the actuator that opens and closes the wastegate |
for all those that think a bov doesn't work with out moving the maf. YOUR WRONG This maf/map/iat car has 0 and I mean 0 problems with running a bov into the air the car doesn't go way rich/lean, the car doesn't stumble or anything. I will have pics/vids very soon!!!
Information on various parts for people!
http://www.turbobygarrett.com/turbob...o_tech101.html Hope it helps a few |
Originally Posted by boostking
(Post 3134800)
some1 make a how to on a BOV if any1 is up for it
*sigh* i guess ill do it when it comes in
for those of you interested in a BOV for the ss./tc synapse turbo has one for you guys, enjoy! |
