New 3d Video of TreadstonePerformance Turbo Manifold
http://www.youtube.com/watch?v=raHKdQ5k0SQ
This is the new video of the manifold that Treadstone Performance is making for the 08+ Cobalt SS
Enjoy!
Enjoy!
They are doing a cast SS most likely to help with longevity. The labor involved is more machine than someone at a table with a jig welding. Once the sand casts are made they can fly through making these. Also who can argue with cast for its strength and stainless is just awesome. Manifold will last 2 lifetimes.
elec, you seem very knowledgeable on this topic, what the advantages of a cast manifold? and anti lag set up..only thing i can think of is nitrouse? explain please thankyou!
wtf is thats supposed to me 09 lol
cast manifolds are very sturdy, and from what I understand retain more heat thus spooling the turbo better.. that being said they're not the best for flow.. but they're worlds better then a log manifold
i also could be wrong and misunderstanding things lol
i still dont understand the anti-lag you guys mentioned... and if your saying the only advances are structual i cant buy that, doesnt welding metal actually make it stronger? anyway... and would ceramic coating make up for the heat issue..... i always thought equal length tube style was the best way to go? coming from a muscle car background keep in mind, i know theres big difference with the turbo and what not
I'm too JDM for you
Ok, so this looks good and all, but how are you going to mount the turbo off the side of the manifold like that? Wouldn't it hit the firewall? when we did my big turbo, ours was a tubular manifold, we actually had to make it sit significantly lower than where the stock turbo position was, and we had to mount it straight off the bottom of the manifold to keep it from interfering with the firewall.
What turbo are you putting on this? I could see it working if it was a small frame GT28, but anything larger i don't see working.
also as far as your turbos go.......you might as well tell people "hey start building your bottom end now." i mean im running a 5557 with a tubular manifold and thats a tight squeeze to begin with(not saying you cant get a bigger one in there) but its good to 535hp. the turbos you guys are doing are all capable of between 600-650 if im not mistaken here. so as far as marketing your turbos theres really nothing there for guys that want to be in the 500 range let alone guys that cant build a motor.
Sit in the corner for a minute.
I'm stupid and even got it right off the bat
i couldnt agree more with you.... the way i see it is you might aswell make a complete upgrade from the stock manifold. if im not mistaken i believe our stock manifolds are cast stainless to begin with. the only upgrade i honestly see from this is longer runners and the ability to run an external waste gate. to me it just seems you would be better off with a tubular manifold.
Stock crank is good for more than that.
SO why do we need to build bottom ends again?
