New TC owner question
Old Jul 7, 2009 | 03:37 PM
Stik09's Avatar
I picked up my new SS TC last week and still have less than 1000 miles on it. My car feels very slooooooow still and was wondering if anyone else noticed it took a few miles to wake up??? The car I test drove flew and was definetly fast. Just courious if I have an issue or need to be patient. I know these cars will spank my GTI, well all but mine... lol ...
thx
Old Jul 7, 2009 | 03:41 PM
Stock?'s Avatar
thx
How much boost? Check charge piping and intake.
Old Jul 7, 2009 | 03:42 PM
rocketrex's Avatar
patience my friend patience and u will feel a diffenence to your gti. and welcome!!!
Old Jul 7, 2009 | 03:47 PM
Stik09's Avatar
thx for the welcome, I do really like the car allot. Boost seems to hold at 15 after a quick spike to 20. I have watched the spark advance and it yanks all timing out almost imediatly but does not record any knock retards. Pipes look ok, I would think if I had a leak it would flash a CEL. Maybe not though.
I will be patient and see what happens, I know my friends stock SS yanks on my modded GTI so I am excited to take my SS to the track.
thx guys...
Old Jul 7, 2009 | 03:50 PM
Permafried-'s Avatar
Ok I have to ask, if it's pulling timing are you running 91+?
Old Jul 7, 2009 | 03:51 PM
BEASTmode632's Avatar
the car has break in periods. the last one is at 1000 miles i think
Old Jul 7, 2009 | 03:53 PM
Stik09's Avatar
Not sure what the dealer put in it but I ran it very low and then put in 93. I thought the first tank if only 89 may have caused it to run poorly. Should I reset the ECU or just drive it and let the car figure it out?
Old Jul 7, 2009 | 03:55 PM
1100psi's Avatar
Are any of you seeing over 15 lbs of boost? I am seeing around 17 in second gear under WOT. The car should be 100% stock but I dunno I bought it used with 7K miles on it.
Old Jul 7, 2009 | 03:57 PM
umrdyldo's Avatar
I am mostly stock and see 16-17PSI in the summer.
14-15 in the winter
Keep driving with 91+ and see if the ECM corrects itself (which it should but I forget how many miles it's going to take). If the dealer put 87/89 in it likely pulled timing to avoid knock with the prevous tank of gas (hence it not registering any right now with 93). It will eventually correct itself. That said, the car does improve as the break-in progresses...just make sure to follow the break-in recommendations and she should run like a champ.
cobalt123's Avatar
welcome
Old Jul 7, 2009 | 03:59 PM
Gestapo007's Avatar
...you have a stock TC and boost spikes to 20lbs!? boost should be like 15-16 stock. im over 300whp and my boost is 21lbs
Cuda009's Avatar
I see 15 psi just about all the time. One winter day it was down to 7 psi. ******* learn down.
Old Jul 7, 2009 | 04:02 PM
slowstang's Avatar
Welcome to the site. The boost levels you are seeing are about the same as mine. My car will hit 15 and stay there until about 5000rpm and creep up to 17-18psi. When I first bought my car it wasn't very quick...the more miles I put on it the faster it felt.
Also, first gear has torque management but i'm not sure about 2nd. I know in 3rd gear in this car is a beast
Old Jul 7, 2009 | 04:03 PM
1100psi's Avatar
I dunno my car has 7,775 Miles on it, and is bone stock (at least everything visible dont know about the tune) and it is boosting like 17lbs under WOT.
Old Jul 7, 2009 | 04:05 PM
It's entirely dependent on your elevation...since your location doesn't specify where you are I'm going to assume it's normal for you to be slightly higher.
Old Jul 7, 2009 | 04:06 PM
rocketrex's Avatar
what dealer did u get her at? i work for vandergriff in arlington and they lie! saying they put 93oct but nope 87 all the way. if u can bro get a trifecta tune theres a guy in the de ef dub who does it for 200 bucks! look in our regional forums
Old Jul 7, 2009 | 04:09 PM
fshizl's Avatar
it spikes to 17 psi. after about 5k rpm... but normal boost for mine is 15... in any gear, at any point before 5k rpm
Old Jul 7, 2009 | 04:10 PM
northvibe's Avatar
I just got to 1300 miles and yes the car opens up very much after 1k miles. Just wait. I test drove Cuda's then bought a new ss with 7 miles and was like...wtf this feels slow. So just wait.
Old Jul 7, 2009 | 04:21 PM
Stik09's Avatar
Sounds good, If I disonnect the battery will it pickup the better fuel faster? I bought it at Classic in Grapevine.
I was going to give it a couple K and then get a tune. cant wait for that. Origonlly I was going to make this my daily driver and get a big turbo for my MKV. After I drove one of these and readup I changed my game plan. I am going to make this beast my weekend warrior and the Vdub the daily driver. The SS just has sooo many goodies already on it. Makes me proud to own a Chevy again... hehe...
Old Jul 7, 2009 | 04:29 PM
Uhh disconnecting the battery may or may not help...someone else can comment. I'd just leave it as is, keep pushing premium fuel through it, follow the break-in and see where it goes. Mine is starting to wake up about 3000 miles in (that's a rough conversion from km) so just be patient, she'll get there .
Old Jul 7, 2009 | 04:33 PM
northvibe's Avatar
I broke my ss in pretty hard, hit 140mh a couple times and some twisty stuff. But yeah At 1k miles disconnect the battery for a little bit, some say it helps idk the car just woke up slowly then it hits you one day that its faster than when you bought it lol.
Old Jul 7, 2009 | 04:34 PM
1BADSS/SC's Avatar
thx
stock TC's are slow. Mod that sucker.
Old Jul 7, 2009 | 04:39 PM
Regardless it still shouldn't be pulling timing...sheesh
Old Jul 7, 2009 | 04:44 PM
1BADSS/SC's Avatar
lol
TUNE OUT THE TIMING!
