No-Lift Shift is Giving Me Trouble :-(
Hey guys...
I have had my car for 2000 miles now and I have yet to experience no-lift shifting. I can't seem to nail it for some reason. I have a few questions:
- Do I have to use launch control in order to use the no-lift shift feature?
- If not, do I still put the car in launch control / competitive mode?
- While making the shifts, I keep my throttle wide open while pushing in the clutch and
shifting. I must complete the shift in less that .2 seconds, correct?
The only reason I am asking such stupid questions is because the car doesn't even try to retard the timing (or whatever it does) to lower the RPM, it immediately redlines the car as soon as I press in the clutch. I'm sorry that I keep bringing up this same topic, but I'm really having trouble and the dealership doesn't understand what my problem is. They say it shifts fine and have not heard of the no-lift shifting. They do not have any documents on it either. Thanks for your time....
Jake
Jake
Competition mode ON, don't need to use launch control, throttle to the floor constantly through the shifting. I've heard people not liking the 1st to 2nd no-lift, have you tried 2nd to 3rd?
Ya, it won't lower the RPM at all. I have gone through 1st, 2nd, 3rd, and 4th with full throttle attempting the no-lift and the car never attempted to lower the rpm between shifts, not even for .2 seconds. :-(
It's not supposed to lower the RPM.........it's supposed to hold it to keep boost up.
It keeps boost going by dumping fuel and pulling timing to heat the **** out of the exhaust.
Why would you want to lower the rpm while doing full throttle shifting???
Either way, the RPM redlines. It slams up to redline the second I push in the clutch.
You would want to lower the RPM so that it will be better syncronized with the transmission once the clutch is dropped. I though that was the point. I'm dumb though and I'm still learning.
Yes but if you drop the redline then you kill the engine load and there is nothing to spool the turbo if the load is gone. The transmission will drop the revs just fine.
I'm no pro, but I have yet to have a problem with this. The only odd thing I've noticed in the recent month is when I wait too long to shift. It will hit the limiter and fall flat on it's face. But that's my fault - not the car's. If you don't think you're doing it right, swing over to YouTube and search for 'powershift' or 'powershifting' and you'll find tons of vids.
Basically, the best way to describe the procedure is this....
**WITH COMP MODE ON**
As you approach redline during a WOT run, you want to stab the clutch with your left foot and keep your right foot firmly planted....and when I say stab, I mean you pretend like you're Bruce Lee and be on and off that clutch as fast as you can. In the split second your left foot is passing the halfway point in the clutch pedal's travel, you should start your gear change.
**SIDE NOTE** You can feel the point where the clutch disengages by applying a bit of pressure on the shifter. When trying to feel it out, do so on normal shifts until you have a good understanding where that point is. Then, you can translate your understanding to the NLS.
Back to the stabbing... You need to be completely in the next gear just before you get back to that same point of travel on the rebound. If you're not coordinated enough to accomplish this, you probably shouldn't be 'no-lift shifting' (aka powershifting) your car.
That's pretty much all there is to it. Just be cautious on the 2>3 upshift - it's probably the easiest one to miss. That and redline. The tach is a little slow to respond - so you may have to start the 1>2 earlier than the rest of your gear changes to avoid the 'falls on it's face' part.
silly question but are you taking it to redline before attempting to shift? because if your not and you do no lift shift of coarse the rpm are gonna fly up higher... because you say youv done it from 3rd to 4th and thats 110+mph so im just thinking you may be trying to use it without going to redline? which will not work so well for the clutchy
http://content.gmownercenter.yahoo.c...alt_owners.pdf
That's the owners manual. I thought there was something in there about NLS....but upon further inspection, couldn't find anything. Sorry.
Actually you want to be shifting before you hit the clutch... it sounds odd i know... it what my dad told me when i was still driving my 79 Camaro and i gave him the look....
Right Foot Firmly Planted on the Throttle Pedal... Shift AND Mash the clutch at the same time...
now i drive an SS/SC so my RPM's go flying up but from what i read and hear your RPM should hold steady...
I've done it this way everytime im at the track (granted not first -> 2nd gear but the rest)
This is just my .02 so...
Thats the key. It has to be done as one fluid motion, and it has to happen really fast. If you are thinking about any part of it while doing it, you are taking too long. I've WOT shifted my car and many others, you just have to go for it. As long as the car is set up correctly it works out fine, the SS/TC just has extra electronics to make it easier on the drivetrain, so they can advertise it from the factory. It will achieve the same effect anyway if you shift very fast without lifting your right foot.
Try taking it all the way up and doing it just as you're hitting redline. I was using it at the track and it works well and you can hear the characteristic "pop" if you do it right and listen carefully. The thing I don't like about the 1st to 2nd shift is that it's really harsh, especially with the stock mounts. After watching some videos or my track runs you can also hear the tires chirping even on the 2nd to 3rd shift.
its all good sniper, i knew what you meant, just didnt want people to start rammin that gearbox around without clutching
Ive wotshifted more times than i can count,
and as i said in the other big thread about it, no-lift shift hasnt proven itself to be anything more than a gimmick to me so far.
I LOVE IT! Again, why would people get on here to say how much they love using something and tell everyone how they get it to work perfectly. All of the people posting about it are complaining because they don't know how to use it...
Simmer down fella.. im sure there are lots of people who love it, like yourself for example... we were just simply stating some helpful hints to ease them into knowing how to do it!
I dont doubt for a minute that if you know how to use it its fun (i.e. - hahn at the track!)... i wouldnt have said i didnt want to try it if 95% of the people were complaining....
